Cold Start Issue
Old Nov 14, 2009 | 08:53 PM
PaysonPSD's Avatar
PaysonPSD
Originally Posted by Quick444
Thanks Robin! I would rep ya but I got spread it around some more.
I really need to pick up a volt meter.
Just a cheap test light could help you narrow it down.
Old Nov 17, 2009 | 03:20 AM
Quick444's Avatar
Quick444
Alright still a clickin!
When I turn the key, the sound is definitely from the relay. If I unhook that cable and try to jump it via my battery using jumper cables, I get nothing at all.
I kept turning the key over and over while my friend tapped the starter and I got it to turn once but unfortunately I let go of the key.
Old Nov 17, 2009 | 05:22 AM
just another truck's Avatar
just another truck
I vote for starter replacement.
Old Dec 11, 2009 | 07:11 AM
Quick444's Avatar
Quick444
Well I put in a new starter and it sounds great turning over. However, I still get the clicks too.
Starter relay? What cost am I looking at?
Old Dec 11, 2009 | 07:41 AM
Smokin''s Avatar
Smokin'
Smokin
Clicks or buzz?...I only get clickin and buzzin if my battery terminals are dirty.
Old Dec 11, 2009 | 07:43 AM
just another truck
Originally Posted by Smokin'
Clicks or buzz?...sounds like batteries
I vote for loose battery connection...
Old Dec 11, 2009 | 07:57 AM
Kwikkordead's Avatar
Kwikkordead
I've solved a lot of starting problems on various vehicles by simply installing a jumper wire between the alternator output post and the positive terminal of the battery.
In addition, install a dedicated ground wire for the alternator to the same battery.
Pictures always help.
Old Dec 11, 2009 | 08:00 AM
Quick444's Avatar
Quick444
Occasional click and then I can go to town on it over and over again and occasionally it will turn over.
Brand new batts and starter.
Old Dec 11, 2009 | 08:04 AM
Smokin''s Avatar
Smokin'
Smokin
We're thinking the culprit are your cables and/or connections, not the batteries themselves. A loose connection (even one that seems tight) can cause a lot of problems.
Interesting rigging there Dan.
Old Dec 11, 2009 | 08:06 AM
Kwikkordead
Exactly!
A chain is only as strong as the weakest link.
Ever since I installed that wiring harness, the volt gauge on the truck has moved up to a slightly higher position.
And the voltage at the batteries are exactly the same as the voltage at the output post of the alternator.
Old Dec 11, 2009 | 09:15 AM
Quick444's Avatar
Quick444
Dan, thank you for the picture. I don't know if you have done a simple write up on how to create such a mod but it could be very helpful for others. While I get the basic idea and I have even taken an engine out and put it back in my truck, I wouldn't dare rig something up like that without reading a good write up on it first.
I am dead nervous about things that I don't get laid out crystal clear before I try it.
Once the sun comes up I am going to try and make it to town and solve my gelling issue. If I can figure that out then I hope to make it the 1.2 hours down to the "big" city of Wasilla where hopefully I can get some new bolts for the battery cables. They are rather loose.
Old Dec 11, 2009 | 07:57 PM
Quick444's Avatar
Quick444
Starting issue seems to go away when cold and happen when hot.
Old Dec 11, 2009 | 10:26 PM
  #28
tdpower's Avatar
tdpower
re
That's a great idea. You're just putting the hot wire in parallel instead of series. Ground wire sounds great as well. Good post and reps to you.
Old Dec 12, 2009 | 01:47 PM
  #29
RFD_Truckie's Avatar
RFD_Truckie
I had this very same issue with an old 78 Bronco I had. (351M) I changed countless starter relays since it would fire each time I changed one, just figured it was goin thru them for some reason I couldnt figure out. Turns out, It was the main ground wire at the frame. Followed the ground wire from the battery, cleaned it up, never had another problem....
Wish I still had that Bronco....
calvinbabb
Dec 1, 2014 02:07 PM
bradahl
1997 - 2003 F150
Aug 21, 2014 05:20 AM
RedDevil460
69
Mar 22, 2014 11:39 PM
dburke8088
Jan 7, 2014 11:21 AM
jitterymonkey
Nov 12, 2013 08:07 PM
