Vaccum Reading
Old Nov 11, 2009 | 09:31 AM
Recoil's Avatar
Recoil
Vaccum Reading
I did a vacuum test on my truck last night, and I think it was pretty good. However the needle doesn't really hold steady at idle, it flickers a little bit, is this normal? You can see it towards the end of the video.
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf?file=http://vid245.photobucket.com/albums/gg63/wkpeterman/Truck/vacuum.flv">
Old Nov 11, 2009 | 09:02 PM
fmc400's Avatar
fmc400
MSEE
It looked pretty steady to me; I'd think a variation that small would have more to do with the needle than the actual vacuum reading. Maybe someone else has a different opinion.
Old Nov 11, 2009 | 10:09 PM
berry1234's Avatar
berry1234
Looks great to me. The needle will vibrate a bit with cheaper gauges. I have that one and it does the exact same thing.
Old Nov 12, 2009 | 01:04 AM
Tees77f150's Avatar
Tees77f150
Looks like mine to, and I agree don't look to bad to me. I assume your running good?
Old Nov 12, 2009 | 08:58 AM
Recoil's Avatar
Recoil
Thanks guys. Yeah, it is a cheap gauge, it was $10 at Harbor Freight.
It runs really well, but sometimes has an uneven idle. I think it was my air fuel mixture. I had to richen it up a bit when I put the gauge on, haven't driven it since though.
Old Nov 12, 2009 | 05:26 PM
Tees77f150's Avatar
Tees77f150
Yup! Thats where I got mine too! Harbor Freight can be your friend for sure!!
I just used mine and now from a cold start, I just hit the gas one time, and it fires right off.
I still shake my head in disbelief as this truck after setting in a barn for 20 to 22 years was a siezed up fight ALL the way for the most part.
Old Nov 12, 2009 | 08:46 PM
yankeerebel's Avatar
yankeerebel
Recoil, I did the same thing to my truck after battling for some time to find out why it didn't run well. Even with the vacuum/mixture dialed in, my truck will sometimes still have a funny lope occasionally at idle. With a stock truck that old it could be just cam wear or carbon buildup on a valve or just an old ignition module. Just run it wIDe Open!
Old Nov 14, 2009 | 09:04 PM
montana_highboy's Avatar
montana_highboy
The camera work is more unsteady than the needle lol, the needle reading looks fine to me.
Long-shot
Modular V10 (6.8l)
May 13, 2014 06:48 PM
StephenHCable
47
Sep 26, 2013 07:31 AM
overlandexpress
Oct 19, 2009 10:45 PM
iridium
Mar 24, 2008 01:28 PM
bluneon
May 2, 2006 10:51 PM
