360 Vacuum Diagram
Old Mar 24, 2008 | 12:11 PM
iridium's Avatar
iridium
360 Vacuum Diagram
Here's the skinny. I had my engine rebuilt some time ago by a shop. The more that I am working on my truck myself, the more stuff I am finding that they screwed up (and I can't make them fix it as they went out of business).
So, My heating and A/C vacuum is not hooked up and I want to get it hooked back up and make sure that all of the other vacuum hoses are hooked up correctly.
So, I'm Looking for a Vacuum Diagram for a '74 360.
Saw posts, posted by Million, directing to other webpages (https://www.ford-trucks.com/forums/687546-vacuum-diagram-and-part-number-request.html?highlight=360+vacuum+diagram) but they were "page not found" when I went there (photobucket).
Any help is greatly appreciated.
Thanks
Mike.
Old Mar 24, 2008 | 12:23 PM
Mil1ion's Avatar
Mil1ion
Just so you know ,access to them all is through the links in my sig.
I have 4 online resources of things
My Gallery
Photobucket
Web shots
ClubFTE web site
do you have an M/T or A/T
F-100 ?
A 74 truck will have a code starting with 3.
ie: 3-53E
Old Mar 24, 2008 | 12:37 PM
iridium's Avatar
iridium
It is a F100
I have a C6 Automatic (which as a side note has not worked properly since I purchased the vehicle LOL cant shift into 1 or 2 only into D)
Wow! you have lots of awesome info on your photobucket webpage! So once it leaves the cab and goes to the manifold I didn't see where it attached to the manifold. Should it go to the top part of the PCV valve on Passenger side rocker cover or should the A/C Heater Vacuum hose go to the vacuum hose tree behind the carb?
Old Mar 24, 2008 | 01:09 PM
Mil1ion's Avatar
Mil1ion
It should hook up to a vacuum tree
Here is your diagram
Old Mar 24, 2008 | 01:28 PM
iridium's Avatar
iridium
Thanks! I will use this and the interior vacuum hose diagram off your webpage tonight and see what I come up with.
kr98664
Jan 8, 2024 01:18 AM
Ol School
Jan 24, 2017 08:12 PM
subford
29
Jul 4, 2016 06:11 PM
Parsedout
20
Apr 12, 2015 12:18 PM
levirox
Electrical Systems/Wiring
Dec 12, 2006 08:20 AM
