Sponsored by: Kumho
rubber spring booster for a inch upfront?
Old Nov 10, 2009 | 11:36 PM
93f250tn's Avatar
93f250tn
So i wanted to lift the front end up a inch or so on my 95 f150 4x4 so it sits level and when i buy new tires i can put 33s on. I came across these 1 3/4" rubber coil spring boosters that are only 18 bucks. I dont offroad its a road truck i do go muddin once a month or so but i dont flex the suspension at all. Will these fit my needs? any issues i need to worry about? should i just go with the 1" coil spring spacers? or could i even go with the 2 1/4" spacers ? heres the link AutoZone.com | CoilSpringBooster | 13/4in.approx.jumbofrontcoilspringbooster
Old Nov 16, 2009 | 07:44 PM
dtingle89's Avatar
dtingle89
those sound good. i drive an f350 and i put a level kit with 2" spacers in my front suspension, just be sure to align the front after your done getting them in. im like you, i dont do too much off roading.
Old Nov 16, 2009 | 11:22 PM
Ford_Six's Avatar
Ford_Six
The only issue with those is that Ford uses a strap and two bolts to hold the upper end of the coil in place, rather than just trusting it to stay there or using a center pylon like other manufacturers.
Another thing to consider is that that will cause camber issues due to the TTB system. You really need to go all or nothing with that system.
Old Nov 18, 2009 | 08:05 PM
dtingle89's Avatar
dtingle89
yeah i did have to buy aftermarket camber adjustment bolts for my 2" level, but that was only $40 in all. bought the level kit on ebay for $50.
awq134
2009 - 2014 F150
33
May 3, 2024 10:16 AM
Toreador_Diesel
Jan 1, 2021 03:28 PM
mic91F150
Dec 23, 2015 09:12 PM
octaneforce
Sep 1, 2015 05:28 PM
ScallyWaggler
May 16, 2015 02:17 AM
