90' 7.3 e40d problems
Old Nov 10, 2009 | 08:06 PM
babbler's Avatar
babbler
I currently have a e4od in my 90 4x4 f250 7.3, and i'm having the ususally problems,some slippage once in awhile, and shifting up and down, i had faullty tach sensor and replaced that tonight,it seems better got rid of the harsh and hard shifts, but still isn't right, the truck has sat for some time and drove much in the past 5 years, replace tranny filter and fluid last winter and maybe put on 30 miles, i checked the filter last night to see if it fell off and it was still on, so i'm lost on where to look now,goes right into gear and right into reverse, so i'm looking for some advice!! thanks
Old Nov 10, 2009 | 09:01 PM
David85's Avatar
David85
How many miles on it? (and is this a factory build)
What gears is it slipping in?
Does the converter clutch slip too?
Does the slip happen under load or at light throttle? (does it make any difference?)
Does it behave worse or better when the transmission is cold? ( does it make any difference?)
Do your brake lights work?
Old Nov 10, 2009 | 09:26 PM
babbler's Avatar
babbler
it is a factory rebuild with roughly 65000 miles on it, brake lights work, when you running at highway speed it it will rev up like it came out gear but didn't, i think it kinda slips between 2nd and 3rd, and between 3rd and 4th, slips pretty much only under heavy throttle and load,
Old Nov 10, 2009 | 11:23 PM
David85's Avatar
David85
So the RPMs go up by about 300-400 RPM? or is it a complete loss of drive?
Was the cooler replaced when the transmission was overhauled? Did they install an inline filter on the return line from the cooler (required)? If so, you might want to try replacing that filter.
Have you tried having any codes scanned?
Old Nov 11, 2009 | 12:17 PM
babbler's Avatar
babbler
yep they just go up about 3-400 rpms, im pretty sure theres no inline filter, i have yet to to try pull any codes, thanks for your help
Old Nov 11, 2009 | 12:34 PM
Lazy K's Avatar
Lazy K
Good advice on getting any stored codes. It could be a bad range sensor or bad connections to it. If so it would show up in the codes. However you could try cleaning the plug connectors to it.
Old Nov 11, 2009 | 12:39 PM
babbler's Avatar
babbler
thanks will try that tonight report back with results i hope!
Old Nov 11, 2009 | 06:38 PM
babbler's Avatar
babbler
okay i bought a scanner and scanned it tonight and got some codes,i got 10,11 and 22,23 i see that it say the tp sensor is out of range, how do i fix that and where is that on ip? thanks!
Old Nov 11, 2009 | 07:18 PM
Marianna2003's Avatar
Marianna2003
The TP sensor is on the driver's side of the IP. Mounts with 2 screws.
Last edited by Marianna2003; Nov 11, 2009 at 07:19 PM. Reason: correct item identification.
Old Nov 11, 2009 | 08:58 PM
babbler's Avatar
babbler
is it something you have to replace or ajust? thanks
Old Nov 11, 2009 | 11:40 PM
David85's Avatar
David85
First, did you hold it to the full power position. If not, then you will get a false fault code.
Next, test the voltage. You want 0.8-1.2V at idle and 3.8-4.5 at WOT.
Ideal is 1V idle and 4V WOT, but some trucks like different settings.
Next, test how smoothly the voltage changes as you work the throttle. This is best done with an analog meter if you have one. Its easier to see how smooth the signal ramp is than on a digital (but digital will still work).
Code 22 is barometric sensor (altitude sensor). I think its located on the climate control air box under the hood near the AC drier.
Don't know code 10.
Old Nov 12, 2009 | 07:23 AM
babbler's Avatar
babbler
i'm confused what should i hold full power? thanks
Old Nov 12, 2009 | 02:06 PM
rupejosh's Avatar
rupejosh
on the throttle rocker on the passenger side of the ip.
Old Nov 12, 2009 | 03:38 PM
David85's Avatar
David85
Rrrrr, been trying to reply since last night but couldn't get through.
Yes I was talking about the throttle.
So ignition on, engine off, depress the accelerator pedal all the way, then connect your code scanner to read codes.
Old Nov 12, 2009 | 07:04 PM
babbler's Avatar
babbler
thanks will try it again, i did it again earlier and got all them again and #63 but i will try it with pedal all the way down thanks!
