1st title bad really need help with this
Old Nov 10, 2009 | 06:53 AM
srqdiesel chef's Avatar
srqdiesel chef
missed deer hunting way too long post
Yesterday when I left work, she started right up but stalled about a block later. had a tough time getting her restarted and only went another b4 she died and would not restart.
I noticed about a week ago that the fuel guage was getting weird and researched it here. My selector switch has been grounding out and is evidently dead. when i check it with a meter I get 10-11 volts if I check power, but can't get anything over 1 when I check switch terminals.
Could my selector switch be stuck in no man's land so I'm not getting fuel from either tank? I've checked the schrader valve for pressure and the batteries both read 12+, but when I try to start it the starter clicks really loud. How many issues do you think I have? Is it the switch or something with the starter or both?
Old Nov 10, 2009 | 07:57 AM
srqdiesel chef
Could my selector switch be stuck in no man's land so I'm not getting fuel from either tank? I've checked the schrader valve for pressure and the batteries both read 12+, but when I try to start it the starter clicks really loud. How many issues do you think I have? Is it the switch or something with the starter or both? <!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig --><!-- sig -->
__________________
Old Nov 10, 2009 | 08:48 AM
farmert's Avatar
farmert
On my 85 I had a simular problem , and it was the fuel selector valve located on the driver side frame rail. With the starter click, sounds like you toasted the starter trying to restart after it died.
Old Nov 10, 2009 | 07:21 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Basically five wires on the tank selector valve.
Three of them are for the fuel gauge, two for switching tanks.
When you switch tanks, the polarity of the power is reversed causing the valve to switch the other way.
I seem to have lost the wiring notes I had.
Old Nov 10, 2009 | 11:55 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
i got your back Dave:
Originally Posted by allerickb
As requested.
<table style="width:194px;"><tr><td align="center" style="height:194px;background:url(http://picasaweb.google.com/s/c/tran...background.gif) no-repeat left"><a href="http://picasaweb.google.com/allerickb/FordDualTankWireDiagram?feat=embedwebsite"><img src="http://lh3.ggpht.com/_KCpQ4xYjSAY/SryOVecGIwE/AAAAAAAAIfc/PwmQgDkk-wo/s160-c/FordDualTankWireDiagram.jpg" width="160" height="160" style="margin:1px 0 0 4px;"></a></td></tr><tr><td style="text-align:center;font-family:arial,sans-serif;font-size:11px"><a href="http://picasaweb.google.com/allerickb/FordDualTankWireDiagram?feat=embedwebsite" style="color:#4D4D4D;font-weight:bold;text-decoration:none;">Ford Dual Tank Wire Diagram</a></td></tr></table>
allerickb,
Welcome to FTE and the IDI diesel forum.
So on the stock fuel selector valve connector,
Pin 1 is away from the fuel line end of the valve.
Pin 1 & 2 are the wires from the selector switch that swap hot and ground to run in opposite directions.
Pin 3 goes to the front tank sending unit
Pin 4 goes to the fuel gauge
Pin 5 goes to the rear tank sending unit.
https://www.ford-trucks.com/forums/8...ve-wiring.html
Old Nov 11, 2009 | 09:10 AM
srqdiesel chef
thanks
Thanks for the guidance, turned out I had a laundry list, selector switch, bad alternator(which had no ground wire), voltage regulator and a short in the ignition. took all day to track it all down, runs better than ever, but it has a weird click now when it's in gear and going down the road.
jb10725
Oct 14, 2014 08:05 PM
cchrrice
Feb 2, 2012 10:22 PM
Hydropower Luke
Jan 4, 2012 04:47 PM
jbhjlch
Mar 13, 2006 09:09 PM
ink
Nov 1, 2000 03:27 PM
