6.0 Trans Cooler
Old Nov 11, 2009 | 04:27 PM
Izzy351's Avatar
Izzy351
Originally Posted by Barndon
ok some one school me on the trans cooler. and why would we want to put a 6.0 trans cooler, rather then the stock one made for 7.3 ? how does it benefit the truck ?
The stock cooler on our trucks are actually very small. Here are pics of both the IC and trans cooler.
7.3L coolers:
6.0L coolers:
Old Nov 11, 2009 | 04:49 PM
ztodd377's Avatar
ztodd377
I'd like to do the intercooler swap eventually on mine. Isn't there a hose size difference between the 7.3 intercooler and 6.0 intercooler?
Old Nov 11, 2009 | 05:34 PM
Izzy351's Avatar
Izzy351
Yes -- on mine, I needed one tapered boot, and one straight. On the stocker, they're both tapered.
Old Nov 11, 2009 | 05:52 PM
triskit16's Avatar
triskit16
Last stupid question...I just cut the lines and clamp on the new ones?!
Old Nov 11, 2009 | 06:48 PM
Barndon's Avatar
Barndon
is the 6.0 intercooler better than ...say... an aftermarket intercooler designed for teh 7.3 ?
Old Nov 11, 2009 | 07:43 PM
jkidd_39's Avatar
jkidd_39
No.. but can be found for $100-250.. try finding a spearco or banks 7.3 IC for less than $1000
Old Nov 11, 2009 | 08:11 PM
Izzy351's Avatar
Izzy351
The line on the passenger side of the trans cooler is replaced completely. You clamp a new 3/8ths line between the adapter you attached to the bottom of that side of the cooler and the steel line going to the trans. For the driver's side, you cut the steel line after the bend, turn 180 degrees and attach the short piece of 3/8ths between there & the cooler on that side.
It's harder to explain than to do, I think. You leave the steel line on the passenger side of the radiator intact. So the flow goes from the trans, to the radiator, to the new cooler, back to the steel line returning to the trans...
Old Nov 11, 2009 | 09:03 PM
rbaker6336's Avatar
rbaker6336
Do you have a cooler in the radiator?If not I think I figured it would be better to replace the lines from where the steel lines end.I haven't installed mine yet
Old Nov 11, 2009 | 10:06 PM
triskit16's Avatar
triskit16
I don't even know right now. Its been raining here for over 24 hours now and it probably wont stop til tomorrow sometime. When I get a chance I can look at everything a lot closer and see what exactly I have on my hands and get my bearings on which line is which.
Old Feb 7, 2010 | 08:29 PM
damicofuel's Avatar
damicofuel
My early 99 did not have the cooler in the radiator, just the littlr dude in front.
Old Oct 5, 2010 | 06:42 PM
jbounds's Avatar
jbounds
My turn for a question!!!! Better late than never
When you replace the I/C & Trans cooler, your replacing the radiator as well? or is it seperate than that and you keep your stock 7.3 radiator
Old Oct 5, 2010 | 06:53 PM
jkidd_39's Avatar
jkidd_39
You keep your stock radiator. Any more questions just holler
Old Nov 11, 2011 | 08:01 AM
  #28
microdevil45's Avatar
microdevil45
Quick question, if I wanted to change out the ic/ trans cooler where do I get tapered boots for the ic to fit the 7.3? I can make the fittings for the trans that's isn't a problem. Thanks
Old Nov 11, 2011 | 08:56 AM
  #29
Franko72's Avatar
Franko72
Molon Labe
Give Clay a call, he has the reducer boots you'll need for the 6.0 intercooler swap.
Riffraff Diesel: RDP CAC Intercooler Single Boots
bossgobbler
Mar 16, 2017 11:56 PM
MoBill122
Nov 26, 2016 11:58 AM
arizonian
Jun 19, 2016 11:41 AM
LSO1123
Mar 27, 2016 07:58 PM
Volcom
Aug 1, 2015 07:24 PM
