Sponsored by: Real Truck
FLOOR SHIFT CONVERSION
Old Nov 8, 2009 | 09:50 AM
snoplw's Avatar
snoplw
I would like to convert my 99 F250 auto, 4wd to a floor shift, anybody done it-- if so what are the pitfalls & what did you use ?
Old Nov 8, 2009 | 01:07 PM
BobbyDiesel71's Avatar
BobbyDiesel71
you would have to replace the transfer case in your truck(ESOF)vaccum operated/engaged) to a manual shift transfer case.
It can be done, there is a hole in trans hump with a plate cover.
Old Nov 8, 2009 | 04:25 PM
06silvercrew's Avatar
06silvercrew
No you dont, I coverted mine and still has the ESOF case in it.
Old Nov 8, 2009 | 06:48 PM
snoplw's Avatar
snoplw
I have a manual xfer case so I guess I'm all set. which kit did you use?
Old Nov 8, 2009 | 06:56 PM
1975StroppeBaja's Avatar
1975StroppeBaja
Here's a recent thead on the subject.....
https://www.ford-trucks.com/forums/8...ion-build.html
Old Nov 8, 2009 | 07:10 PM
06silvercrew
I guess you need to be more clear. Are you wanting to adapt your transmission to floor shift or transfer case?
Old Nov 8, 2009 | 08:01 PM
snoplw's Avatar
snoplw
transmission
Old Nov 8, 2009 | 08:21 PM
TexasRebel's Avatar
TexasRebel
I've been rolling the idea around in my head about puling my Twin I-beams out and putting a front axle in... with manual hubs and a manual T-case...
I'll have to win the lottery first...
Old Nov 8, 2009 | 08:53 PM
1975StroppeBaja
hmmm... yeah I missed the mark on that one too...
Old Nov 8, 2009 | 10:36 PM
Pinky Demon's Avatar
Pinky Demon
I think the better question is...why?
Old Nov 8, 2009 | 10:52 PM
Robs06SuperDuty's Avatar
Robs06SuperDuty
im with Pinky... Why?
Old Nov 9, 2009 | 07:11 AM
snoplw's Avatar
snoplw
After a night of plowing driveways ,my arthritic shoulder, is very sore from the up / down motion of going from drive to reverse. I think the forward / back motion with a floor shift would lessen the pain in the shoulder. To be more clear -- I have a manual xfer case & a auto trans. The conversion kit I'm looking for is for the trans.
Old Nov 9, 2009 | 08:59 AM
redford's Avatar
redford
FTE Leadership Emeritus
Instead of a floor shift, how about a pushbutton selector?
Push-Button Electronic Shifter From RetroTek Speed
Old Nov 9, 2009 | 06:46 PM
snoplw's Avatar
snoplw
Thanks Redford-- I will check on that right now.
Old Nov 9, 2009 | 07:54 PM
Pinky Demon
Don't bother. Your clutch will be gone after a year. There is a reason an automatic transmission is a de facto standard for plow trucks.
