Half way there
Old Nov 7, 2009 | 04:26 PM
throwdown's Avatar
throwdown
Half way there
Well, I just got done for the day and so far so good. The turbo is still on the bench waiting for the WW to be installed and the foil delete is done. Under valve covers is done. Re-torqued, changed glow plugs, and Ford clips were already in play at the UVCH connection. Probably some past work at dealership. New up pipes are installed and that's enough for today. I'm sure I will feel plenty of special spots from laying on top of that engine.
New IC boots from Clay will go in tomorrow as well as HPX and FRX, and then the turbo and cross your fingers..........ignition.
Old Nov 7, 2009 | 04:30 PM
Izzy351's Avatar
Izzy351
Wow!! That's a lot of work all at once!! Good job!
Old Nov 7, 2009 | 04:51 PM
87 F-150 I6's Avatar
87 F-150 I6
That is a lot of work, nice job
Old Nov 7, 2009 | 05:01 PM
Bigcat350's Avatar
Bigcat350
WOW Patrick thats a nice little chore you done today. I bet you do feel it a little sore in the morning but its well worth it. At least you have the hardest done hopefully it all lines up for you.
RedBoat's Avatar
RedBoat
Rather Be Floatin
Wow, you are getting alot done in one weekend!
Good work.
Old Nov 7, 2009 | 05:40 PM
throwdown's Avatar
throwdown
Thanks guys. We are having two warm days and I figured this is the time to do it.
I want to do all I can while the turbo is out of the way.
I'm not much on pictures (pretty common stuff really), maybe an after shot, who knows.
Old Nov 7, 2009 | 07:40 PM
PaysonPSD's Avatar
PaysonPSD
Damn Patrick, I hurt just reading about all you did today. But you can't waste the warm weather.
Old Nov 7, 2009 | 07:42 PM
megawatt00's Avatar
megawatt00
Sound like a very productive day man!
Old Nov 7, 2009 | 08:37 PM
F350-6's Avatar
F350-6
Congrats on the progress made so far. How many loose bolts did you find under the valve covers?
Old Nov 7, 2009 | 08:56 PM
hucka1a's Avatar
hucka1a
Good job, that's definitely a good day's work.
Old Nov 8, 2009 | 01:08 AM
Sheldon Plankton's Avatar
Sheldon Plankton
Originally Posted by throwdown
....Under valve covers is done. Re-torqued, .....
Am I reading that right? Did you torque the valve cover bolts with the engine in the truck? How in the heck did you get in there with a torque wrench?
Old Nov 8, 2009 | 05:58 AM
throwdown's Avatar
throwdown
Payson...I don't dare waste the warm weather, but you have plenty. I miss my days in Wickenberg.
F350-6...The only loose bolts I found were the injector hold down bolts, which took about a full turn each. All rocker bolts were right on for torque.
Sheldon...Actually, I was talking about the injector and rocker bolts under the valve covers. However, it takes some patience but with the right wobble sockets you can get most anything. 8ft lbs all around for the valve cover hold down bolts.
Today's dilemma will be finding a 5/16 twelve point socket to take the turbo apart. Imagine my surprise when I went to the box and found only a gap where the little rascal is supposed to be.
Old Nov 8, 2009 | 09:45 AM
PaysonPSD's Avatar
PaysonPSD
Yes, plenty of warm days here. At 5,000 ft Payson does get cold in the winter months, but nothing like Ontario. BRRRRRR!!!!
Hope everything goes smooth for you today.
Old Nov 8, 2009 | 09:50 AM
throwdown's Avatar
throwdown
So far so good. Installing FRX now. Spider and uppies are in. WW is in but turbo not on truck yet.
Old Nov 8, 2009 | 10:22 AM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Wow Thats a lot your doing at once congrats.
