Half way there
Old Nov 8, 2009 | 10:50 AM
throwdown's Avatar
throwdown
Thanks, stuck at the FRX though.
Old Nov 8, 2009 | 10:58 AM
big poppa's Avatar
big poppa
Let me guess, them bloody fuel plugs, right???
Old Nov 8, 2009 | 11:18 AM
throwdown's Avatar
throwdown
No, that's not it. I didn't get longer screws with the FRX and I'M not sure if I can get any locally on Sunday.
Old Nov 8, 2009 | 11:22 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
They should be in a small plastic bag with the business cards.
Old Nov 8, 2009 | 12:02 PM
Izzy351's Avatar
Izzy351
I'm curious as well how many bolts you had to tighten. Since I put injectors in, I'm thinking I'll pull the VCs and check the torque again after a thousand or two miles...
Old Nov 8, 2009 | 03:53 PM
throwdown's Avatar
throwdown
IT'S ALIVE..........started right up, and away we go. No leaks yet. Clay got me squared away on the FRX and everything seems to be a go.
Old Nov 8, 2009 | 04:35 PM
throwdown's Avatar
throwdown
Izzy351... all the injector hold down bolts needed tightening. Everything else was good. Stock injectors, 358,465 Kilometers.
I discovered that I have a starter bolt broken while I was under there, so that must be the next project.
Old Nov 8, 2009 | 04:48 PM
Izzy351's Avatar
Izzy351
Thanks Patrick. That's what we've been seeing all around. I think it might be a good idea to pull the VCs once a year and torque injector bolts...
Old Nov 8, 2009 | 05:21 PM
throwdown's Avatar
throwdown
Right now I've got "alternator chest", I don't even want to think about it.
I blew a lower cold side boot on the test run, and so far that's all the problems I've encountered (crossing fingers).Bilsteins are in the mail, so that's next Friday.
Try to get done before the snow flies.
I think liberal amounts of VO is in order for the rest of today.
Old Nov 8, 2009 | 05:43 PM
big poppa's Avatar
big poppa
So those fuel plugs came out no problem for the FRx?? Why I ask is, I must be the only one having problems with these things... Glad your up and running there dude..
Old Nov 8, 2009 | 06:30 PM
throwdown's Avatar
throwdown
Thanks...Of course I had everything out of the way...that helps a lot I'm sure. The passenger side was a bear to start the new fitting but, I got it.
I could not have done all this if it wasn't for FTE and you guys and gals. I had pretty much given up on fixing my own stuff due to too much electrical voodoo under the hood. I'm really beginning to enjoy it again thanks to you folks.
Old Nov 8, 2009 | 06:34 PM
hucka1a's Avatar
hucka1a
Great job Patrick!
Old Nov 8, 2009 | 06:38 PM
  #28
throwdown's Avatar
throwdown
Thanks... next stop... DP Land.
Old Nov 8, 2009 | 07:02 PM
  #29
Waltdog's Avatar
Waltdog
of American machinists
Nice job! I have been looking to do the FRX myself
Old Nov 9, 2009 | 09:01 AM
  #30
throwdown's Avatar
throwdown
Well this morning I put about two hours drive on my truck and I can see no problems.
I like the whistle, better spool up and throttle response, seems to be quieter and smoother.
Thanks to all for the help and info I received.
Now a question...When I started it this morning, (not very cold) the EBPV acted like it was coming on and off, sort of like a surge. When I touched the throttle it went away.
Is that because of the temp, or did I do something wrong when I reinstalled the turbo?
