On the left side of the turbo, under the exhaust valve is an actuator arm that extends form the pedestal to the EBPV. There is a small clip that has to be removed and the arm disconnected from the valve. Use a needlenose pliers to grab the clip and push to the drivers side of the truck to disengage. It should come off, hold onto it tight, it's a special clip found only at your Ford dealer
Can't find a picture of the actual clip. Still looking.
Really all you need to do is slide the clip towards the drivers side and lift up on the rod. The little clip on the wastgate does not need to come off, it stays with the turbo. Only the EBPV rod needs to be decliped.
