yet another egr question
Old Nov 6, 2009 | 05:38 PM
MAS96F150's Avatar
MAS96F150
ok i have a 96 f150 5.0l. i put on a set of 69 351w heads and wanted to know if i could remove the vacuum lines from the harness and the two plastic sensors (that face the upper plenum) on the braket that holds my coil. there is no egr pipe between the two heads that have the solenoids that these two sensors operated. will it set off my cel? about two years ago i broke my egr pipe between my upper and lower intake because i bent it to much when it was cold . i have one from a 90 in it now but it dosnt have the two ports going to the small sensor next to the throtle cable brakets and when i had it tune he said that he shut that part of it off so it wouldn't light the cel.
Old Nov 6, 2009 | 08:08 PM
rla2005's Avatar
rla2005
I think you are referring to the AIR pipe and TAB/TAD solenoids. You can remove the vacuum lines without setting a CEL. If you unplug them electrically you definitely will throw an error code without some more reprogramming of your PCM.
cekingsley
3.8 & 4.2L V6
Sep 28, 2013 03:27 PM
RustyTrustyF150
Mar 19, 2012 09:35 PM
BobbyB
Apr 21, 2011 07:13 PM
5. Slow
Dec 18, 2007 10:05 AM
jason86
1997 - 2003 F150
Nov 16, 2006 07:11 AM
