Haunting CEL
Old Dec 8, 2007 | 12:32 PM
5. Slow's Avatar
5. Slow
Haunting CEL
Hi everybody,
My truck is a '96 F150 4x4 302 with 120,000. I have had troubles with my CEL coming on for the past two years. First time I threw a code for my O2 sensors. I changed both of those out, and what a pain in the *** it was changing the one on the passenger side manifold. CEL came off and no problems. About six months ago CEL came on again. Ran the code for egr valve flow insufficient. So I cleaned in out twice because the CEL came back on. So now I ran codes again. But I'm no longer throwing the egr code, instead I'm throwing PO1400, PO171 and PO174!!
This truck is starting to drive me nuts. It's been well taken care for and trouble free since I bought it will 50,000 5 years ago. Please help me get this CEL off.
Jim
Old Dec 8, 2007 | 01:14 PM
danr1's Avatar
danr1
P0140 02 Sensor Circuit No Activity Detected Bank 1 Sensor 2
P0171 System Too Lean Bank 1
P0174 System Too Lean Bank 2
I guess I'd start with a fuel pressure check and find find out why no No Activity is Detected Bank 1 Sensor 2, may just need a new sensor.
Did you watch the reading from that sensor while it was running with the scanner connected? If so what did it show?
Old Dec 8, 2007 | 02:53 PM
5. Slow's Avatar
5. Slow
Dan,
This may sound like a stupid question, but how do I do a fuel pressure test?
Old Dec 8, 2007 | 03:05 PM
danr1's Avatar
danr1
Originally Posted by 5. Slow
Dan,
Not stupid at all, you can buy a gauge to do it, may not be cheap, I have not priced one yet and when I asked for one they didn't have one.
I just had mine checked, at the auto parts I was at that also does repair work and had them check mine.
There is a valve on the fuel rail the gauge connects to, looks like a tires air valve.
The gauge the guy used on mine looked very expensive for a "do it yourselfer".
Old Dec 16, 2007 | 10:05 AM
5. Slow's Avatar
5. Slow
I found a buddy of mine with a fuel pressure gauge and we checked the fuel pressure. It reads 30 psi. That seems about normal right? Any other suggestions to this problem?
Jim
Old Dec 16, 2007 | 11:08 AM
5. Slow's Avatar
5. Slow
Even though the O2 sensors were replaced, could they have gone bad? I would find that hard to believe but is it possible. How about the fuel filter? I changed it out 2 years ago, would that help the lean fuel problem?
Old Dec 16, 2007 | 11:14 AM
ameritaz3038's Avatar
ameritaz3038
i had P0171 and P0174
when i checked my pressure i was at 30 also, a few monthes later guess Fuel Pump took a dump completely
after replacement it clear my code in about 15 miles.
I only repalced one pump but both where shot.
Old Dec 18, 2007 | 10:05 AM
5. Slow's Avatar
5. Slow
Mike,
Thats interesting, well I just have to plan replacing that darn thing when it does decide
to go out. Is it bad that I'm running the engine with those codes thrown?
Jim
Oly-f250
Jul 8, 2014 05:37 PM
BRay09
15
Mar 5, 2011 02:44 PM
scatgo
Dec 12, 2009 05:12 PM
Butch(OH)
Modular V8 (4.6L, 5.4L)
Jan 27, 2009 06:06 AM
tinkybug
May 8, 2006 12:20 AM
