Sponsored by: Auxito
Seat convert to power?
Old Nov 3, 2009 | 10:02 PM
hcbph's Avatar
hcbph
Been trying to research this with little luck, so I'm asking the question: Is it feasible/possible to convert a 60x40 manual seat in a 97 Scab to power on the drivers side? Been looking at some diagrams and looks like you can just swap out the base/track on the drivers side and add power to convert it to a power seat.
Can anyone confirm if my analysis is correct or has done this? If it is, looks like the base would have to come from a 97-03, again is this correct?
Appreciate any thoughts/ideas on this. If you know where there is a writeup on doing this, would appreciate that too. Thanks
Old Nov 6, 2009 | 03:38 AM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
Well i know that my truck has the power hook up for the power seat underneath the drivers seat. I would start by looking for the whole in the carpet under the drivers seat and see if you can fish a power wire out. After that its just plug and go and bolt i guess.
Old Nov 6, 2009 | 07:37 PM
n5926g's Avatar
n5926g
I did it on my old 97 XL...found some leather buckets out of a Lariat.Bolted right in,and I ran a B+ and ground line to the fuse box under the hood. As long as you use a decent higher gage wire you should be good to go.
wastingas
20
Nov 30, 2012 08:23 AM
checksix
Feb 17, 2012 04:22 PM
SW_601
Jul 21, 2006 09:06 AM
whitetailhunter
Sep 8, 2005 03:48 AM
Petrol
Apr 29, 2002 04:59 PM
