Timing Chains
Old Nov 3, 2009 | 01:27 PM
thekingofcows's Avatar
thekingofcows
Timing Chains
I have pulled the pan off of my 460, and the timing chain has a little bit of slack if you poke it from the side. Does this mean it is stretched? And if so, what would be the best replacement for it?
Old Nov 3, 2009 | 02:07 PM
OrangeJuice's Avatar
OrangeJuice
It can be used if it has very little slack in it. If you have to replace it, then I would go with a double roller chain. Or you could go with timing gears, but not sure if their available for the 460.
OJ
Old Nov 3, 2009 | 03:26 PM
thekingofcows
How much slack would you say is acceptable?
Old Nov 3, 2009 | 04:24 PM
gstanfield's Avatar
gstanfield
I would say that very little is acceptable. How much do you have from pulled back to pushed foward? (total slack in other words) You can get away with a little and different books call for different amounts, but I generall won't use anything more than about 1/8"-3/16" total slack. Some people will use them with more, but I prefer to use them wih even less.
George
Old Nov 3, 2009 | 04:37 PM
427 fordman's Avatar
427 fordman
If you think its too much just change it. They are cheap and you don't want to break it. Not that much work to change. I would go with a double roller also
Old Nov 3, 2009 | 04:39 PM
gstanfield's Avatar
gstanfield
Another reason to just go ahead and put a double roller on it is that they are MUCH MUCH less prone to "stretch" as well as they wills et your timing straight up instead of retarded as some of the factory sets are made to do.
Go ahead and drop the $40 or so if you can spare it. Your truck will thanks you.
George
Old Nov 3, 2009 | 04:44 PM
Kennewick's Avatar
Kennewick
George
Good point causr Ford did factory retard timeing on some 70's 460's by changing the location of the keyway.
Old Nov 3, 2009 | 07:26 PM
thekingofcows
all right good advice, would ya'll recomend advancing the timing any when I go to put the chain back on.
Old Nov 3, 2009 | 07:56 PM
Kennewick's Avatar
Kennewick
My poor opinnion is unless race Straight up cam time unless you "have" to run EGR. If not then as stated straight up with 38* total with the dizz or less, advance till ping and back off. Check out Cloyes web site and look at thier selection and engineering guide. They have wild sets with multiple keyways and some that are fully adjustable if your into it. Good luck.
Old Nov 3, 2009 | 08:04 PM
gstanfield's Avatar
gstanfield
I usually run cams straight up on a street engine, with a few exceptions. I think puttin git in straight up with a double roller would be as good a setup as you're gonna get on an otherwise stock engine. It'll pep the low end if you have a factory retarded cam timing and the added power will come with some improvement in economy as well.
George
mwkobe
Mar 14, 2010 09:40 PM
djtuna
Nov 17, 2005 12:32 AM
lorenr
Nov 13, 2005 08:44 PM
14 Fords
Mar 7, 2004 12:58 PM
ford390gashog
Jan 19, 2004 12:53 AM
