1995 Wire Harness Question
Old Nov 3, 2009 | 10:00 AM
galkire's Avatar
galkire
I have a 1995 that I bought wrecked and have been rebuilding. Its a bronco, but with the 351 I thought I would get more traffic with the 150 351 people. There is a wire harness at the front end that was cut in half and I cannot figure out what it goes to. Below is a picture, any help would be great.. thanks!
Old Nov 3, 2009 | 11:44 AM
subford's Avatar
subford
It goes to the DRL Module or jumper W/O DRL.
DRL PLUG:
Old Nov 3, 2009 | 12:01 PM
galkire's Avatar
galkire
Great... So I can cap those wires off and shouldn't have any problems right?
Thanks for the quick reply!
Old Nov 3, 2009 | 12:27 PM
subford's Avatar
subford
There should be a plug at the end of those wire with a jumper plugged into it.
But if the truck is wired different than that you may be able to cap them off but if you have problems with the high beam indicator and the dash brake lamp working with the pedal. Then you may have to short some of those wires together.
If so you would need to short the GY/W & the LG/BK together for the high beam indicator.
Also the LG/R & P/W wires shorted together to get the dash brake lamp to work with the Emergency Brake pedal.
dbdbb
Oct 20, 2014 08:53 PM
lenbo
Jun 5, 2008 09:12 PM
bryan gossett
Engine Swaps
Oct 18, 2004 06:39 PM
TCJRBS
Aerostar
Sep 2, 2003 12:43 AM
