Inside tire wear, alignment needed?
Old Nov 3, 2009 | 08:27 AM
02GrayPowerStroke's Avatar
02GrayPowerStroke
I have some wear on the inside of the front tires. Is this just an alignment issue?
Thanks
Old Nov 3, 2009 | 08:32 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Yep! If your ball joints are getting loose now would be the time to replace them.
Old Nov 3, 2009 | 09:35 AM
pbr man's Avatar
pbr man
Could just be an alignment issue. Also check your ball joints and wheel bearings. I had a ball joint showing signs of wear, but not enough to scrub the tires. Then I had a wheel bearing go bad and scrubbed the inside of a tire really bad in 1,000 miles. ended up changing both at the same time.
Max Capacity
Aug 11, 2013 06:03 PM
Nabors
Jun 17, 2013 10:58 AM
ronbarbrey
1997 - 2003 F150
Aug 23, 2012 09:33 PM
jaredgoodwin
Mar 17, 2012 02:48 PM
HUNTER10
Dec 26, 2006 07:41 PM
