rough idle
Old Nov 14, 2009 | 04:47 PM
dustybumpers's Avatar
dustybumpers
sounds good. just change the hose around for the pvc then, the valve should rattle when you shake it.
Old Nov 15, 2009 | 10:36 PM
8525ford's Avatar
8525ford
hey another question. for the carb base gasket on my holley 390. do i need a 4 hole gasket or do i need an open center gasket. I have the clifford with the 4 hole adapter. so do i need a 4 hole gasket. I currently have the open center gasket on there. IS this wrong, and could that be a cause of a rough idle for my truck??? and does anyone know where i can find a gasket for the spacer plate to manifold. I rigged up some gasket but id like to get the right one on there?? thanks
Old Nov 16, 2009 | 04:43 AM
dustybumpers
I have the 4 hole gasket on top of my adapter, and the open one below.
Old Nov 16, 2009 | 04:33 PM
8525ford's Avatar
8525ford
okay i'll switch it around. anyone know the part number from summit for the 4 hole gasket and the one below the spacer???
Old Nov 16, 2009 | 04:51 PM
dustybumpers
just go to pep boys or somewhere like that. they have mr gasket , they come with 4 holes, but have a perferated line where to cut out the square. I don't remember how much the cost, but I think I got 2 for under $8
gwindsor
Jul 3, 2016 08:12 PM
gwindsor
Jun 29, 2016 11:56 AM
amsnss
Jan 16, 2014 05:45 PM
pomial
Jan 21, 2007 10:13 PM
65inline6
Apr 30, 2002 12:24 AM
