clifford
Old Jun 29, 2016 | 11:02 AM
gwindsor's Avatar
gwindsor
clifford
Has anyone run the 6=8 performance set up from Clifford performance. I have a 1982 f-100 short flare side with a 4.9 l six. This set up sounds interesting however I have heard of problems, especially with their cam
Old Jun 30, 2016 | 09:45 AM
Talltruck's Avatar
Talltruck
I have a 300 with a Clifford intake that's been together for over 30 years with no issues. I used a Comp Cam but Clifford has been there for a really long time so I think they've been time proven and they make parts nobody else does.
Old Jun 30, 2016 | 09:12 PM
gwindsor's Avatar
gwindsor
Thanks for the reply. I have noted that others stay away from their 264 cam and select the comp.
Old Jul 1, 2016 | 04:49 PM
jason832's Avatar
jason832
I have an intake and shorty headers from them, and I like them a lot. The intake has a heat passage along the whole bottom which makes a difference especially in winter. I'm not sure if the offenhauser intakes have it or you may have to install a heated spacer or something.
I'd stay away from their cams, there has been some warnings on this site and fordsix.com saying they are manufactured with low quality, and for the high price that they ask for a cam it's a no brainer to go with a different comapny.
https://www.ford-trucks.com/forums/9...m-warning.html
I've ran both the clifford and the comp 268, and I think it's fair to say the comp pulls just as hard through the entire rpm range, but after 3500 or so the comp runs away.
Clifford has some good intakes and headers, but stay away from the cams. Here's the specs on their cam if you want something similar:
206/206@.50
.474/.474 Valve lift
110 LSA
Hope this helps.
Old Jul 1, 2016 | 08:27 PM
F-250 restorer's Avatar
F-250 restorer
A cam on the 300 is different than with many v8's. It is good to know what you intend to use the engine for before buying a cam. Is it used for work, towing/hauling, and needs the low end torque? If so, maybe the comp 268 is not a wise choice. Is it simply a daily driver?
I have a good thread over on the fordsix performance forum, entitled 351 pistons, where there is much knowledge about cams. BTW, the same thing you've read about Cliffy cams I've heard about comp lifters.
Old Jul 2, 2016 | 07:44 AM
Talltruck's Avatar
Talltruck
I have mine setup with a Comp 260, and to me it's always been an impressive setup for low end torque. It's in an F250 4x4 with 38" tires and it will idle in 3rd gear rolling down a dirt road but still wind out pretty good.
Old Jul 3, 2016 | 08:12 PM
gwindsor's Avatar
gwindsor
Thanks for all the info. safe to say that I will stay away from the Clifford cam and do some research regarding other manufactures.
F-250 restorer
40
Nov 8, 2017 10:27 AM
soundguy567
18
Aug 7, 2011 11:31 PM
JLoyd77F250
Mar 28, 2009 11:48 PM
Burg460
Oct 31, 2008 01:41 PM
MIKE 351
Jul 29, 2002 12:34 PM
