i cranked the motor too hot while trying to get my motor started, i replaced the solenoid on the fender well and put a new starter in it, i needed one anyway. well when i turn the key it warms the glowplugs then feels spongy, theres no resistance from pre ignition to ignition. and i had some smoke coming from the ignition wires coming to the fender solenoid. any ideas im stumped, checked fuses, wires and just dont know what is goin on with this truck anymore
You're positive your battery cables are good? Also make sure you're well grounded, smoking the solenoid sounds like something is grounding out or a lack of a proper ground on the negative side of things.
the cables arent in the best condition but its never given me problems, also whats with the key ignition feeling really loose? theres no play between pre ignition and the starting position. im gonna go through the wiring tomorrow, is there a specific fuse or relay it can be?
The problem with the key switch is probably either a bad ign/start switch (bolted to the steering column under the dash) or ign/start switch out of adjustment or the ign switch actuator (connects the key switch down the column to the ign/start switch) is bad.
its the ignition actuator napa had one in stock for 18.00 its a pain to get to though, lol. i got bad electrical stuff goin on but this is one less problem i guess. thanks for the input guys
