Not sure to tell you the truth. There are a lot of guys on the 2004 - 2008 F150 part of this site that have done it. You could go on there and ask some questions. I wish I could help you more but I just don't know.
Just put on my AS 2" leveling kit and now the front is 1/2" taller then the back it don't look bad but now I know and it will bug. What to do now? Put another block in or does someone have a suggestion
Is your truck a 4x2? I have a 2010 4x2 and I've measured mine and the rear sits exactly 2" higher than the front. I'm thinking of putting the 2" AS kit on mine.
Did you measure yours before starting and are you sure you didn't use a 2.5" kit? I know AS sells one. Also, did you align your truck after the install? This can make a difference as well.
I measured but I really didn't take an exact measurement I remember thinking 2" so I ordered the 2" kit cause they said that it would still have some rack I can send you some pics if you would like so you would see what it looks like. I'll try to get them in my gallery
Thanks, The more I look at it, it looks pretty even (even though it's 7/16 higher)I was thinking of trying to get a 1 1/2" block for the back so the back would be alittle higher but I think I'll let it sit and try to find some 275/70R18's for it.
