2" level kit
Old Apr 8, 2017 | 07:25 PM
Richard Aarts's Avatar
Richard Aarts
2" level kit
I am planning on installing firestone ride rite air bags in the rear and would like to put a level kit in the front. What are your guys thoughts on the best kit. I've read a lot about having to change caster angle and adding other things after installing the kit. Would like to keep it simple and not have any noticeable differences when driving. Thanks
Old Apr 8, 2017 | 08:08 PM
Austin_F100's Avatar
Austin_F100
I went with the Ready Lift, and have been very happy. Great kit. Got it aligned by the shop that installed it, and no problems. Just received my air bags, but haven't put them on yet. Hope this helps.
Old Apr 8, 2017 | 08:45 PM
Richard Aarts
Did you have to add the track bar relocation bracket?
Old Apr 8, 2017 | 10:33 PM
Outtacontrol58's Avatar
Outtacontrol58
I am wondering the same Richard Arts. Is the relocation bracket needed with the ready lift level kit??
Old Apr 9, 2017 | 02:21 PM
EpicCowlick's Avatar
EpicCowlick
Maybe I can jump in here. If you consider the geometry of the front end, you'll realize that the axle is shifting left and right all the time in normal course. When the front end compresses down, the axle shifts to the passenger side. When it unloads or lifts (like when installing spring spacers or any kind of level), it shifts to the driver side. The fixed point of the motion is the track bar end where it bolts into the trac bar bracket. The whole point of adding a bracket is to center the axle when the truck is in its most common position, which is no load. If you level the front end 2 inches, the new steady-state will shift the axle approximately 1/2 inch to the driver side.
So do you "need" a track bar bracket? Well, technically no because the axle is still within its normal range of motion albeit a little shifted from the factory position. There's probably some specified range that the axle can travel left or right before it starts binding abnormally on the control arms, etc. I don't have the engineering specs to know what that range is so we just kind of assume it's ok if nothing feels abnormal when driving. The trac bar bracket will simply restore the resting or steady-state of the axle to it's intended factory position and would remove any concerns of out of range travel due to a lift of level.
Old Apr 9, 2017 | 02:41 PM
user 474747383's Avatar
user 474747383
Good info Epic
I only level our trucks 1 1/2" in the front RC Coils, But I do use the Bracket mostly because I can't stand the tire sticking out on the drivers side. If it shifted the other way Pass side I probably wouldn't because I never see that side, but I see that tire sticking out every time I approach the truck. Also the 9" offset wheels just make it worse. Is it necessary Ehhh 2 1/2 and up probably. I know when I added the first one the steering wheel was 180* off, So i had to recenter the wheel again.
shark1979
6.7L Power Stroke Diesel
23
Dec 8, 2013 09:46 PM
riored4v
2004 - 2008 F150
Nov 5, 2007 03:33 PM
superv10
Jul 21, 2007 06:22 PM
Abaddon
2004 - 2008 F150
Sep 7, 2006 11:55 PM
bigtexan99
2004 - 2008 F150
Apr 5, 2005 09:03 PM
