code help
Old Nov 2, 2009 | 03:06 PM
snakedoc's Avatar
snakedoc
code help
I put a super chip 1705 on my truck to see if it had some codes, there came back 2 01-P0470 and 02-P0603 what dose these mean? i drove it for one day and the codes are back, no lights on the dash on bad running, don't know what to think. also is it OK to run the SC on the PERE-TOW with on gages at this time, pulling nothing.
Thanks
Old Nov 2, 2009 | 03:44 PM
hucka1a's Avatar
hucka1a
P0470 Exhaust Back Pressure Sensor Circuit Error
Welcome to guzzle's Exhaust Backpressure Sensor Cleaning Maintenance Web Page
P0603 Internal Control Module KAM Error
This one is normal on a chipped truck, nothing to worry about.
Here is a link to all the DTC codes. http://www.superdutypsd.com/codes.php
Old Nov 2, 2009 | 03:48 PM
snakedoc's Avatar
snakedoc
the code was on the truck before it i put the chip in, not sure if it has every had a chip before or not.
I just need to check the sensor and not worry about the other?
Thanks
Old Nov 2, 2009 | 04:41 PM
hucka1a's Avatar
hucka1a
Thanks
Yeah, its nothing to worry about. It's the Keep Alive Memory, you can disconnect the batts and that code will come up also.
Old Nov 2, 2009 | 06:37 PM
F350-6's Avatar
F350-6
If the P0603 showed up before the truck was chipped, I'd recommend cleaning the battery cable connections. Remember each cable has 2 ends. Clean both sides. Poor battery connections can also set this code. With winter coming on, checking battery connections is something all of us need to do, even if we don't have any codes set.
jgilrfr
Dec 3, 2013 06:38 PM
Flytyme69
Jun 4, 2010 12:21 AM
PlatinumPSD
Oct 4, 2007 08:09 AM
florintopa
Canadian National Chapter
Feb 24, 2007 01:13 AM
cathlabdog
Oct 26, 2006 10:58 AM
