Hedman headers
Old Nov 2, 2009 | 09:24 AM
71_4x4_390's Avatar
71_4x4_390
Hedman headers
Anyone else have clearance problems with Hedman headers, FE and 4x4 (1971) applications? Looks like I will need to notch the frame where the motor mounts attach to the frame on both sides. #1 and #5 tubes each are against the frame... Grrrrr!
DD
Old Nov 2, 2009 | 07:55 PM
Riderman's Avatar
Riderman
I purchased the Hedman Elites (inner chassis\frame) for a 76 4x4, FE, and they are a perfect fit.
Old Nov 2, 2009 | 08:16 PM
Argess's Avatar
Argess
I had that problem with Hedman Headers on a Pontiac BB in a 69 Firembird. I just made some square plates to go between the frame motor mounts and the engine block rubber motor mount isolaters. They were about 1/4" thick, but one could go thicker.
All you need is to cut them out about the same size as the motor mount pad and drill a hole in the center for the motor mount bolt/stud. I went a little further and cut a section out from the hole to one edge so I could slide them in wihtout having to raise the engine very much.
Old Nov 2, 2009 | 09:37 PM
71_4x4_390's Avatar
71_4x4_390
I guess I didn't make my explaination very well in my rant. The #1 and #5 tubes each hit the saddle on the frame where the motor mounts attach. Nothing comes close to the mounts themselves. My options are to bend the pipes 1/4"+ and risk a crack later, or just notch the frame saddles. I'm opting for the latter.
Old Nov 2, 2009 | 09:55 PM
Riderman's Avatar
Riderman
Were these the Elite series? Hedman assured me if mine did not fit, they would refund the money.
Old Nov 2, 2009 | 10:46 PM
Bear 45/70's Avatar
Bear 45/70
A small dents or indentations in the header tubes will not effect the headers efficiency. Easier, cheaper and safer than notching the frame.
Old Nov 3, 2009 | 09:54 PM
1969Highboy's Avatar
1969Highboy
You must not have gotten the right set for the truck, my hedman headers fit perfect on my 1969 ford highboy 4x4, i was just disappointed with how they were treated and how they looked when they were considered "new"
bassman755
Jun 2, 2011 08:23 PM
Brad Brown
Jan 4, 2007 04:20 PM
johaner78
Exhaust Systems
Nov 10, 2006 09:25 PM
