Need some help
Old Nov 2, 2009 | 01:34 AM
IdahoanMarine's Avatar
IdahoanMarine
Question Need some help
Hey guys so im station in Okinawa right now but im coming back to the states for my next duty at the end of the month. Im driving a '92 F-150 Flareside but its been awhile since I've actually got to work on it I remember the last time i was on leave i noticed the tailpipe had some bad rust damage and i was wondering if you could give me any good replacements. Im want to replace the entire muffler for sound and hopefully some better gas milage. Also its got leaf springs on it how hard would it be to put a lift on it im thinking about 6", or what's an estimate to get one professionally installed. Thanks for the help.
Old Nov 2, 2009 | 02:04 AM
Iraqveteran's Avatar
Iraqveteran
Is it a 300 six or v8?
Old Nov 2, 2009 | 02:10 AM
TexasGuy001's Avatar
TexasGuy001
If you want a better muffler go with Magnaflow or Dynomax. I woudn't recommend Flowmaster since it drones.
I got this info from another FTE member.
You don't have to use everything listed here in this quote. You could just use the muffler and tailpipe or another muffler of your choice.
Originally Posted by rla2005
I learned a few tricks from the Bronco guys. Bassani 58150B2 y-pipe designed for a Bronco. Magnaflow 59929 3" converter and 12279 muffler and finished with a Maremont 45683 3" tailpipe. All the Bassani and Magnaflow pieces are SS. The Maremont is aluminized steel. For clamps I used Dynomax 32219 SS band clamps.
I installed everything in my home garage with no air tools. Purchased a few rubber donut style exhaust hangers from Auto Zone, everything worked out pretty well. If I were to do it again I would use a little shorter muffler...but then I would need a little extra length of 3" pipe....
Old Nov 2, 2009 | 02:24 AM
Iraqveteran
If its a six heres some exhaust clips https://www.ford-trucks.com/forums/7...und-clips.html
I have true duals no cat with 12 inch glass packs. But here and Arkansas we dont have state inspection there ran under the bed before the rearend turn down. It sounds good to me its a 87 supercab with a built 351w. You will get many different answers on here. I have to say this is a great site with lots of good people to help. Hope you get the answer your looking for.
