Fuel mileage
Nov 1, 2009 | 06:51 PM
Fuel mileage
Hi!
Does anybody know what is approximatively the fuel mileage of a 1991 F-150 4x4 with the V8 and the 5 speed?
Is there a big difference with the 6?
Thanks everybody!
Nov 1, 2009 | 06:52 PM
302 or 351w v8?.............makes a lot of difference.
Nov 1, 2009 | 06:54 PM
Nov 1, 2009 | 07:06 PM
13-15mpg city.........17-18mpg hiway.......20mpg hiway if driven very conservatively and in good tune.
Nov 1, 2009 | 07:20 PM
Mileage response
Our 1996 Bronco 302 5-speed (3.55 gears) MPG readings run 14.5 to 18 - depending on city vs highway & winter vs. summer fuel blend.
dn.
Nov 1, 2009 | 07:52 PM
Well thanks. But is there a difference bitween the v8 and the 6 cylinder, I do a lot of highway. I don't want to change my truck, I realy like it, so......
Nov 1, 2009 | 09:01 PM
All else being the same... same truck, trans and gearing, the I6 doesn't do any better.
Nov 1, 2009 | 11:15 PM
Yeah, like Conanski said it will be close to the same. I think the I6 can do better than the 302, but only very slightly and definitely not noticable.
Nov 2, 2009 | 03:38 AM
mine is currently knocking down 17-18, but its really in need of a set of tie rods, it has almost a 1/4 turn of play... if your 5.0 runs good, i would just stick with it, it wouldn't be worth the swap unless you were (at minimum) already swapping.
88 f150 extended cab
5.0, 5 speed, 4x4, 3.55's
k&n, electric fan, stock size tires.
superdutyfan
6.7L Power Stroke Diesel
Feb 25, 2011 06:55 AM
hedhntr
Aug 29, 2007 05:15 PM
Stampede
1983 - 2012 Ranger & B-Series
Feb 6, 2005 09:31 AM
chandlerbf
Jul 28, 2004 05:09 PM
Halfast
Jul 5, 2003 04:15 PM
1990 ,
1995 ,
302 ,
4x4 ,
50 ,
92 ,
96 ,
capacity ,
f150 ,
ford ,
fuel ,
mielage ,
mikeage ,
mileage ,
truck
