Lifted Our Excursion
Old Mar 24, 2010 | 10:38 PM
  #31
BP22's Avatar
BP22
Thanks Bronco!
Post pixs when you are done.
Old Mar 25, 2010 | 06:35 AM
  #32
myblkex's Avatar
myblkex
Originally Posted by broncorif
I'm planning the 22210 front and 22415 rear lift (stock block) next week. After reading the posts by Yellowsled and BP22 and after BP22's response to my earlier post (rep points given), I went ahead and called Summit and ordered the front springs, rear springs and the Skyjacker dual front steering stabilizer. I'm going to determine the correct ubolt length once I get the springs. Then I'm going to get new ubolts from a local spring shop.
I've never attempted this type of work on a vehicle, but I'm going to give it a shot while the family is out of town and I have an extra vehicle to drive.
Once the lift is complete, I'll decide what tires to get. I currently have 16X8 Cragar Soft 8's and Nitto Terra Grappler 295/75/16. Planning to order some 35's once I see how the lift turns out.
I'll post an update once the springs are installed. Hopefully some time next week.
Anxiously awaiting
By the way -- Did you also pick up replacement Shocks for front / rear ? and are you using any block in the rear springs ?
Old Mar 25, 2010 | 11:12 AM
  #33
njstevens's Avatar
njstevens
I have a procomp lift all spring. Fronts are 23311 and rears are 22410 with small shim to level. If that help anyone. My lift is approx 6". I run 35 inch general AT2 tires. I have no rubbing atty all on fender or spring.
Old Mar 25, 2010 | 08:42 PM
  #34
broncorif's Avatar
broncorif
Originally Posted by myblkex
Anxiously awaiting
After reading more posts in the forum, I decided to buy Rancho RS9000XL's. 4wheelonline has 4 RS9000XL's on sale for $329.95 with free shipping and Rancho has a $100 rebate (in the form of a $100 Debit Card). Since I've had good luck with Summit and I had ordered the other parts from them, I had Summit price match ($329.95). Summit price matched and included the free shipping and no handling charge.
I just have to submit the rebate form to Rancho to get my $100 Debit Card (Same as if I purchased from 4wheelonline)
I'm planning to use the stock block for the rear. I believe I read that 4X4X4RV used stock blocks when he did the same lift.
Looking forward to the install. Hopefully I get good weather next week.
Last edited by broncorif; Mar 26, 2010 at 10:15 PM. Reason: Change of Plans - Bought shocks
Old Mar 31, 2010 | 09:05 PM
  #35
broncorif's Avatar
broncorif
Completed the install of Pro Comp 22210 (Front) and 22415 (Rear) springs yesterday. Took me and a buddy about 9 hours, including two separate trips to the spring shop to get new ubolts. Two trips because we wanted to complete the front before lifting the rear.
I'm extremely thankful that I had an electric impact gun. I don't have an air impact so this was the next best thing. It saved lots of work.
Unfortunately, I did the rear lift the first time with the rear block. Made the rear sit 2 inches higher than the front when we were done. I removed the blocks today and the EX now sits level at approximately 43 inches all the way around. I also installed a Skyjacker dual steering stabilizer today.
I took the stock ubolts to the spring shop so they knew exactly what measurements I needed and I just told them how long to make them. I believe I added an inch for the front ubolts. Turned out to be a good decision since I had not accounted for the steering stabilizer attaching to the driver side ubolt. My rear ubolts are now too long since I removed the rear block so I could have probably had the new ubolts made at least an inch shorter than stock.
My new Rancho shocks haven't arrived yet, so I put the old shocks back on and took it for a drive. I drove at 25, 35, 45 and 55 and didn't notice any vibrations. I took it easy since the stock shocks are almost maxed out. Can't wait to get the new Ranchos on this week.
Total costs
Pro Comp 22210 - 250
Pro Comp 22415 - 270
Skyjacker dual steering stabilizer - 130
4 Rancho Shocks - 329 before Rancho $100 rebate
Front ubolts - 39
Rear ubolts - 50
I already have 16 x 8 wheels and 295/75/16 Nittos. So it looks good, but planning to get 315/75/16 tires soon.
Many thanks to all who have posted their input on their lifts and experiences and to all who have assisted in answering my questions. What a great forum and a great group of people.
Old Apr 1, 2010 | 06:26 AM
  #36
myblkex's Avatar
myblkex
POST PICS !!!
Great to hear that it came out the way you like. I'm looking at doing the same setup , so be ready for a lot of questions - LOL
So you ended up using no blocks in the rear ?
Now go post some pics !
Old Apr 1, 2010 | 07:33 AM
  #37
Macmathews's Avatar
Macmathews
Total costs
Front ubolts - 39
Rear ubolts - 50
Please post pics.. We need more info on the ride once the rancho's are installed !
Kyle
Old Apr 1, 2010 | 07:48 AM
  #38
TeamMudd's Avatar
TeamMudd
LOL, what's the saying now "no youtube...... no proof"
looking forward to some pics too!!
Old Apr 1, 2010 | 03:30 PM
  #39
broncorif's Avatar
broncorif
Correct, no rear block. Send any questions you have and I'll try to answer the best I can
I'm new to posting pictures and I'm working with a blackberry. I posted a picture in the "garage" portion of the profile. Let me know what you think. Be honest. It won't hurt my feelings because I know I like it.
Old Apr 10, 2010 | 06:48 PM
  #40
broncorif's Avatar
broncorif
Figured out how to post pictures using photobucket. Here's a couple pictures.
Here's the Ex
Here's a picture of the front wheel space with 295's. I will be buying 315's soon.
Love the new look and new ride quality. The steering is now better, the ride is better and the look is better. So far I've set the Ranchos on setting 3 and it's great.
Old May 4, 2011 | 05:42 PM
  #41
islander1808's Avatar
islander1808
Will the lift that you guys have done require the shocks to be changed all the way around? I desperately need to replace my stock leafs all the way around and I don't want to pay the stealership for OEM parts/installation. The Pro Comps will accomplish what I'm looking for and they are priced very reasonably. Also... do you fellas think that 285's will look ridiculously small with the new lift? I put them on about a month ago and I have 50k miles before new tires....
Old May 4, 2011 | 09:14 PM
  #42
broncorif's Avatar
broncorif
I don't know about the shocks. I would guess that you would need to buy new shocks for the lift. I don't think the stock shocks will have enough travel length.
As for the 285 tires, my opinion is that they will look too small. My previous post shows my Ex with the lift and 295 tires, so you should have a good idea what it will look like. I'm extremly happy with the 315s. Maybe you could put on some new tires and sell the 285 tires.
If you're stuck with the 285 tires, I'd still do the spring swap just for the ride improvement. Then add bigger tires later.
Old May 5, 2011 | 01:20 AM
  #43
BigPigDaddy's Avatar
BigPigDaddy
Maybe you could put on some new tires and sell the 285 tires. If you're stuck with the 285 tires, I'd still do the spring swap just for the ride improvement. Then add bigger tires later.
I don't think you will have any problem selling your 285's, you just might not get as much $ as you would like. Lots of trucks run 285's and lots of people can't afford to buy brand new tires.
Old May 6, 2011 | 12:26 AM
  #44
wpnaes's Avatar
wpnaes
Originally Posted by CanadianSmokie
Safety for the little guy....
That little guy'll need a helmet soon, set him up with a bicycle helmet and he'll be eager to help on the next project.
Great thread and project!
npd23
18
Mar 24, 2021 08:18 PM
JRC99408
51
Mar 15, 2021 08:25 PM
armyaviation
Jul 3, 2017 12:29 PM
77 Supercab
Aug 10, 2011 08:46 PM
jchosler
26
Jan 24, 2011 06:42 PM
