D60 RSK Swap with Pics
I did this over my Christmas brake. I found a front D60 from a 97 F350 with 4:10's. I also found a matching rear sterling from a different F350 with 4:10's as well. Both axles came with one ton springs, shocks, brakes, and everything else needed for an easy swap. Here are some pics
The D60
The truck with the D50 TTB pulled
The D50
The Sky manufacturing RSK installed
We welded it in rather than drilling the holes and fastening it that way
The D60 put in after RSK install
A few after pics
Mine next to a stock F250
Before and after
The D60
The D50
A few after pics
Before and after
The D60
The D50
A few after pics
Before and after
The D60
The D50
A few after pics
Before and after
what do you gain with the rsk kit???? i have the d60 swap done and all but what will i gain??? is it just that bar in the front or dose it change the spring mount on front springs under cab as well. do you gain some lift ?? if so how would it work with my 6in lift???
I did this mod in 10 degree weather. Brrrr
Wheels are 16x8 and tire are swaper SSR's D rating 35x12.50R16. Tires have between 10-20% left and gottem for free. They are just nearly impossible to balance so I get a lil vibration on the road
