Connecticut Chapter Join Chapter, Leader:
November B/S thread
Old Nov 12, 2009 | 07:33 PM
  #346
Aerocell4x4's Avatar
Aerocell4x4
Diesel Van Enthusiast
Good evening everyone.
Old Nov 12, 2009 | 07:39 PM
  #347
Aerocell4x4
Originally Posted by Nice Work Truck
Dave do you want to use the trailer this weekend?
Want to yes, able to - not likely.
The trailer wiring harness has yet to get a look-see.
Thanks Andy
Old Nov 12, 2009 | 08:12 PM
  #348
Aerocell4x4
Andy & Jim your advise on Forstner bits?
I need to mill a 2" diameter shallow hole into a plank.
This plank is between the upper & lower panels of a bi-fold door.
I need to cut this hole to accept a flush ring pull plate as the ring pull is going on the interior of the bi-fold door at the center hinge joint.
This is the bit I'm thinking about.
Seems it will cut without the need for the push of a drill press.
I understand that the saw style Forstner bits rip up the edges of the hole.
Old Nov 12, 2009 | 08:59 PM
  #349
Aerocell4x4
Eh Pete:
I found this on burying propane tanks.
Excavation Guidelines for Underground LP Gas Tanks
Old Nov 12, 2009 | 09:24 PM
  #350
Aerocell4x4
Good everyone
Old Nov 12, 2009 | 09:55 PM
  #351
7.3 Rocket's Avatar
7.3 Rocket
Dave the boss (dad) says he's interested in taking a look at the least. I wasn't sure what town your new house is in though.
Old Nov 13, 2009 | 04:09 AM
  #352
rocdril's Avatar
rocdril
Morning Everybody, Its Friday!
Old Nov 13, 2009 | 04:10 AM
  #353
Nice Work Truck's Avatar
Nice Work Truck
Good morning CT
TGIF
Hold onto your hats today, REAL windy down here.
Dave any good bit will work.
Make sure you hold on to it. A drill with a side handle will help a lot, also use a slow rpm.
Old Nov 13, 2009 | 04:15 AM
  #354
gbroehl1's Avatar
gbroehl1
Morning all. I hope I can deal with one more day of insanity. Then its the weekend, yeah!
Old Nov 14, 2009 | 04:50 AM
  #355
rocdril's Avatar
rocdril
Good Morning Everyone! Happy Saturday!
Old Nov 14, 2009 | 06:30 AM
  #356
Nice Work Truck
Good morning guys.
Am I the only one have problems getting the FTE site to load.
I have problems since last night.
It is saying the site is taking to long to lode and is timing out.
Old Nov 14, 2009 | 06:38 AM
  #357
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Padding your post count Dave????
That looks like a Rockler product....(?)
The saw edged Forstner bits are usually high quality enough to leave smooth edges, Most larger sizes have them because a continuous rim would produce too much friction and then start to swell in the hole.
(Ever wonder why large hole saws bind so badly? They are expanding in the hole due to the heat they create. Their large diameter means that even at slow rpm's the speed at the cutting edge is high)
http://www.leevalley.com/wood/page.a...at=1,180,42240
I believe you're thinking of a plumbers Self-Feed bit. And you're right, these will produce some tearout, especially on the exit side.
The lead screw also makes it difficult to control the depth unless your drill has a brake.
But a forstner style bit has a spur and not a screw at it's center.....
I need to cut this hole to accept a flush ring pull plate as the ring pull is going on the interior of a bi-fold door at the center hinge joint.
Old Nov 14, 2009 | 06:46 AM
  #358
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
No Andy, you're not the only one.
I just got a slew of thread notifications in my inbox.
Haven't been able to get on this site until now. At least it wasn't working @ 04:20
Old Nov 14, 2009 | 07:34 AM
  #359
gbroehl1's Avatar
gbroehl1
Good morning all. This is the first time I have been able to access the site in over 24 hours.
Old Nov 14, 2009 | 08:16 AM
  #360
Nice Work Truck
OK thanks guys.
I thought I was going crazy.
