Boost Leak...
Old Oct 31, 2009 | 02:30 PM
PsD007.3's Avatar
PsD007.3
Boost Leak...
is there anyway to detect a boost leak with out buying a boost leak detector?? i have to have one somewhere my truck just isnt spooling like it should..and i get a wiff of diesel in the cab once in a while..
Old Oct 31, 2009 | 02:36 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
If you are getting the smell of diesel fumes and are losing boost it is more likely your up-pipes are leaking...
Old Oct 31, 2009 | 02:40 PM
PsD007.3's Avatar
PsD007.3
ok its just soo hard to see behind that damn turbo, and i cant seem to see anything from underneath
Old Oct 31, 2009 | 02:41 PM
MR5x5's Avatar
MR5x5
Wiff of diesel in the cab... Start with the up pipes. Look for black soot around the top of the pipe where they enter the collector. A little mirror and a flash light helps with this. Make sure all the IC boots are tight. Take a look a the turbine wheel as well. Should have nice clean sharp edges. Got a clean air filter?
Good luck with it. You'll find the culrpit.
Old Oct 31, 2009 | 02:42 PM
Izzy351's Avatar
Izzy351
No detector for up-pipes, other than your eyeballs. You'll have to look around the turbo collector & see if there's any soot.
EDIT: Looks like everyone replied at once! LOL
Old Oct 31, 2009 | 02:54 PM
PsD007.3's Avatar
PsD007.3
its just wierd i just put a wicked wheel in and me n my dad 99.5 are identical except i have an afe stage 2 intake and his is a stock one and it still spools ans whistles louder than mine..i guess i'm going to have to buy the boost leak detector..
Old Oct 31, 2009 | 02:58 PM
Riffraff Diesel
PREMIUM SPONSOR
Izzy has pictures of how to build one. But I would focus on your up-pipes because your not going to get fumes from a intake boost leak.
Old Oct 31, 2009 | 03:10 PM
jkidd_39's Avatar
jkidd_39
Build one! It takes about $15 to make
Old Oct 31, 2009 | 03:12 PM
Izzy351's Avatar
Izzy351
Here's a 3" PVC cap drilled & tapped for an air nipple. All it takes is a 7/16ths drill bit, 1/4 NPT tap, and some teflon tape around the nipple. You might want to scuff up or put a couple small screws around the edge of the cap to give the intake something to bite into so it doesn't fly off... It's amazing how much force just 20-25psi puts on that thing.
Old Oct 31, 2009 | 04:20 PM
alstieg's Avatar
alstieg
also check your exhaust manifolds. both of mine leaked bad at 215k.
Old Oct 31, 2009 | 04:34 PM
PsD007.3's Avatar
PsD007.3
ok like i said i know its gotta be something
Old Nov 1, 2009 | 10:23 AM
MR5x5's Avatar
MR5x5
The spools faster/sounds louder, which are pretty subjective, are on the drive side of the boost, which you will not be able to see with a leak detector. The leak detector will only showl leaks past the turbine. If your uppies are good - check the other things that make boost - turbine wheel condition, air filter restriction. Are you getting coal to the fire? fuel filter, fuel pressure.
Do you have a Boost gage? What sort of readings are you seeing...
Are you really sure you have a problem, or is it just that it seems different than your pop's truck. Different intakes make different sounds, and sound is hugely subjective.
Best of luck.
MR
Old Nov 1, 2009 | 11:29 AM
PsD007.3's Avatar
PsD007.3
thanx man that was a great write up
GondolaRides
Jan 29, 2014 06:56 AM
adam10
Dec 23, 2012 03:52 PM
02GrayPowerStroke
Jul 8, 2009 08:41 AM
makomaker
Jun 1, 2008 03:55 AM
sean23johnson
44
Jan 9, 2007 10:54 PM
