breaks and power stearing
Old Oct 30, 2009 | 06:58 PM
garndog's Avatar
garndog
i have a 01 F-350 diesel . tonight the stearing wont turn, even while moving down the road, and the power breaks take two feet to stop the truck. could it be a fuse or what. im lost and im on deployment with that being my wifes only vehical. any help please. i know the power stearing pump was going. but why the brake thing? help please. im miles and miles away from home. thanks ,mark
Old Oct 30, 2009 | 07:37 PM
Vinford's Avatar
Vinford
I cant help you, but I can tell you i know they are hooked up together somehow.
Someone will be along and give you some info.
Old Oct 30, 2009 | 07:50 PM
rtazz17's Avatar
rtazz17
They are linked together by the" something " booster next to brake fluid filler. If the power steering res. Dropped to low there could be air in system and I know from first hand experience it causes bad pulsating in brake pedal and bouncing of the wheel. If thats the case it needs to be bled through that something or other booster. My dementia is kicking in and I cant remember for the life of me the name of it. But thats all I can think of it possibly being... Others will chime in..
Old Oct 30, 2009 | 07:52 PM
F350-6's Avatar
F350-6
Please post the general area your wife is in so we can try to find a local member to help out. If you're wife is semi mechanically inclined, we'll walk her through things to check using pictures from our trucks on what to look at.
The power steering and brakes are connected since we have a hydroboost system. First thing we need to know is has she been adding "power steering fluid" to the reservoir? The power steering unit actually requires the use of ATF to function properly. If the wrong fluid has been added, a flush is the first thing needed. That is something she can easily do by herself, or have one of her girlfriends help her.
Thanks for your service.
Old Oct 30, 2009 | 07:55 PM
rtazz17's Avatar
rtazz17
Ahhh the hydroboost unit. Now I can sleep tonight.
Old Oct 30, 2009 | 08:01 PM
F350-6's Avatar
F350-6
Great news. I guess my work here is done then.
Old Oct 30, 2009 | 08:11 PM
garndog's Avatar
garndog
we are in atlantic city newjersy
Old Oct 30, 2009 | 08:16 PM
garndog's Avatar
garndog
thats sfter ther master cylender right..
Old Oct 30, 2009 | 08:18 PM
megawatt00's Avatar
megawatt00
We have a few members in NJ If need be I will call them and see if they can help you out.
Thank You for your service!
Old Oct 30, 2009 | 08:22 PM
F350-6's Avatar
F350-6
It's part of the master cylinder. We have a hydro boost master instead of the vacuum boost master the gas trucks run.
The fluid our "hydro" system uses is the ATF from the powersteering pump, which is how this all ties together.
Old Oct 30, 2009 | 08:28 PM
garndog's Avatar
garndog
megawatt i sure could use help. like i said im on a deployment for the coast guard. let me know how much and ****. im stressing out here
Old Oct 30, 2009 | 08:37 PM
megawatt00's Avatar
megawatt00
Family doesn't charge family. I will see what I can do about getting you some help. I will pm you my phone number.
Old Oct 30, 2009 | 08:59 PM
Vinford's Avatar
Vinford
Not something I wanted to here ......................
Old Oct 30, 2009 | 09:21 PM
rat49f6's Avatar
rat49f6
hey everyone im in nj but i honestly know nothing about the hydro boost system
is this something i could be walked through because i maybe able to help but not until next weekend at the earliest
Old Oct 30, 2009 | 09:29 PM
F350-6's Avatar
F350-6
We've got to start somewhere. If you can describe the symptoms and check what we tell you (we can include pictures) then I'd say yes, you'd be a huge help. If it just needs a flush, then you can do this with no problems at all.
