bore sight help?
Old Oct 30, 2009 | 05:58 AM
cjben's Avatar
cjben
bore sight help?
I am going to get a new scope for my remington 870 slug gun. I don't want to spend a small fortune getting it sighted in,and am thinking about getting a bore sighter to make it easier. I have never used one before,can someone recommend a user friendly one that won't break the bank? I have seen the ones at cabela's that look like a shotgun shell and shine a red light down the barrel,will this work? http://www.cabelas.com/cabelas/en/te...exId=cat200006 I am not going to be using it very much,so i don't see the need to spend over $200 on one that doesn't see much use. thanks for the advice!!
Old Oct 30, 2009 | 06:58 AM
00BlueOvalRanger's Avatar
00BlueOvalRanger
I suppose that would work.
In all my years of shooting, I've never used a boresighter to get onto a target.
When I can see through the bore, I've put a 'dot' on the wall and centered the bore on that dot, then, aligned the scope to match the 'dot'.
First shot (at 25 yards) is pretty darned close. Getting 'on the bullseye' at 25 yards, will normally put you (with a rifle) about 1-1/2 to 2" high at 100 yards.
I'm not so sure with a slug gun. (Arcs like a rainbow or an artillary round!!!)
I've been doing that routine for over 30 years, I suppose.
If I can see down the bore, a small mirror works (like a dentist's mirror).
Old Oct 30, 2009 | 08:25 AM
cjben's Avatar
cjben
sounds like a good idea,but how would i do that on my 870 shotgun since I can't remove the bolt and look down the barrel like a rifle?
Old Oct 30, 2009 | 12:08 PM
bpounds's Avatar
bpounds
I've never used a bore sighter either. Always use blueovals method. But as already said, doesn't work well with blind breech guns.
Here is what I would do Ben.
Setup your target at about 25 yards, or whatever distance you are reasonably sure you will hit the target.
Fire one round. Note where it hit your target.
Lock the gun down in a rest or sandbags, with the sights aligned on the original bullseye.
While holding the gun solid, adjust the sights until they are aimed at that first round point of impact.
Fire a second round to verify.
That will do a better job than a bore sight, with only 2 rounds expended.
Either way, you'll need more rounds to finish the job at greater distance.
Old Oct 30, 2009 | 12:22 PM
00BlueOvalRanger
If I can't see down the bore, a small mirror works (like a dentist's mirror).
(Fixed typo!!!!)
Option 1. - On the 870, rack the slide back, and leave the bolt open.
Use a small mirror to see down the barrel.
Option 2. - On the 870, IF the scope is barrel mounted (cantilever mount), remove the barrel and scope and place in a padded vise. Proceed as described in my first post.
Old Oct 30, 2009 | 12:55 PM
Old93junk's Avatar
Old93junk
Like Keith said, Use a small mirror in the chamber.............Some are available from gunshops that have a small light as a part of the mirror, and are made specifically for this application. A good rest is essential for this too, wobbling around and trying to boresight are frustrating as ****!
clux
25
Mar 26, 2010 10:35 PM
mark a.
Jan 26, 2008 07:05 PM
FLgargoyle
17
Dec 7, 2006 08:31 AM
FordTruckGuySTX
19
Oct 10, 2005 07:02 AM
NDrum2005
43
Jun 13, 2004 11:30 PM
