Shot gun choke ?
Old Jan 26, 2008 | 09:36 AM
mark a.'s Avatar
mark a.
Shot gun choke ?
I want to get a new barrel for my 12 gage Mossberg. One that the choke can be adjusted. Is the kind that has the screw adjustment for all patterns any good, or should I get one that uses the different choke inserts ? I'm not going to run slugs through it.
Old Jan 26, 2008 | 11:20 AM
lariat97's Avatar
lariat97
I would get the barrel that uses the different inserts. Check out Brownells.com. They have a huge selection of barrels. I have a Mossberg 835 pump with choke tubes. Its my all around gun that I use for most of my shotgun hunting. Its camo with synthetic stocks. I use it when I hunt in places where I might scratch my shotguns with wood stocks. I never liked the type of choke that you turn to adjust. I don't like the big bulge on the end of my barrel.
Old Jan 26, 2008 | 02:36 PM
stormyrider's Avatar
stormyrider
I would look at cost. You can retrofit an existing barrel with a poli-choke if it has improved cylinder, you may also be able to get a gunsmith to cut the existing choke out of the existing barrel with a reem and use the poli-choke. the poli-chokes have been around a long time and do work, check with a gunsmith and look at the cost to see which way will be easier on the pocket.
Old Jan 26, 2008 | 07:05 PM
jwshobe's Avatar
jwshobe
I personally think that the adjustable chokes make the gun a little barrel heavy. So I use choke tubes, I feel that the gun is more balanced because of it. There is also more of a variety of tubes that you can purchase, so you can "custom fit" your shooting needs.
pchristman
Apr 9, 2006 08:45 AM
z 97ford1
36
Jan 1, 2006 07:03 PM
cjben
Sep 30, 2005 12:30 PM
ejpreston
30
Jun 24, 2004 12:12 PM
NDrum2005
43
Jun 13, 2004 11:30 PM
