Crew Cab Drivetrain!!!
Old Oct 30, 2009 | 01:16 AM
fordtrucknut's Avatar
fordtrucknut
Well...I finally found a decent deal on a Cummins...Bought a Complete 94 P-pumped 3500 Dually regular cab for 2000 bucks...High miles but runs good!!!
Trans will need rebuilt...but it's the 47RH....any of you know if my 205 Ford T-Case will bolt to the back of the 47RH???
<a href="http://s896.photobucket.com/albums/ac167/78crewcab4x4/?action=view&current=Cummins1.jpg" target="_blank"><img src="http://i896.photobucket.com/albums/ac167/78crewcab4x4/Cummins1.jpg" border="0" alt="Crew Cab Engine Donor"></a>
Old Oct 30, 2009 | 03:23 AM
davethecow's Avatar
davethecow
Try Advance adaptors. Ive never heard of that tranny but you never know.
AdvanceAdapters.com | Engine & Transmission Conversion Adapters - Advance Adapters
Old Oct 30, 2009 | 02:38 PM
ChaseTruck754's Avatar
ChaseTruck754
Dave - ask over on cumminsforum.com about the t-case.
Sorry I forgot to call you back last night - but it looks like everything turned out good!
Old Oct 30, 2009 | 03:51 PM
CowboyFromHell's Avatar
CowboyFromHell
I am going through the same process with my 77 F150 thats getting a Cummins. The cheapest and quickest route I have found is use the 23 spline input shaft out of a Dodge 205. The 205 has to be from behind a Cummins that had an automatic transmission behind it. You need a divorced Ford 205, because it has the small bearing input. Swap the inputs, and then, using the Dodge iron adapter from the same transfer case, drill a few holes in the transfer case for the adapter to bolt to. The drilled holes also allow you to clock your t-case to the desired position. Hope this helps.
Old Oct 30, 2009 | 04:20 PM
ulysses69's Avatar
ulysses69
toploader 4 speed
hey fordtrucknut I still have the toploader I just figured out how to find you on advanced search. car savy not the computer. If your still interested it is a toploader 4 speed with Id tag rug-j = commet fairlane is in good working order with lakewood steel bellhousing. if your running 390 got some other goodies I will throw in for ****s and giggles 100 amp alternator 1 wire adjustible rockers with tubes and some other stuff. 450.00 is what I want I live in west sacramento ca. You can contact me by email ulysses69123@hotmail.com or by cell 916-912-7930 jay
Old Oct 30, 2009 | 05:17 PM
1800joedaddy's Avatar
1800joedaddy
NIIIIIIIIICE!!!!!
Old Oct 31, 2009 | 12:34 AM
fordtrucknut
No Problem Steve!!! I figured you were busy...i forgot to call back too...lol
Old Nov 1, 2009 | 11:47 PM
fordtrucknut
Cummins is at my work now!!! Sounds pretty darn good too...now...what to do next...LOL
Old Nov 2, 2009 | 12:46 PM
ChaseTruck754
That's the easy part....
Cut it up of course!!!!!!!!
fordtrucknut
17
Mar 11, 2018 11:51 AM
fordtrucknut
21
Mar 17, 2014 06:48 PM
1973F250CREW
33
Dec 6, 2012 08:53 PM
dysfunction8
17
Sep 9, 2012 12:05 PM
sniper250
Texas Chapter
Dec 4, 2010 07:23 AM
