oil consumption
Old Oct 30, 2009 | 12:19 AM
farmer ford's Avatar
farmer ford
oil consumption
checked oil this morning and had to add 2 qt of oil after about 200 miles or 3/4 of a tank. no leaks found any where but the truck is only running so so. WHERES ALL MY OIL GOING? hope yall can help
Old Oct 30, 2009 | 01:14 AM
thumper869's Avatar
thumper869
blowin any smoke other than black smoke? how long has it been since you changed the oil?
Old Oct 30, 2009 | 09:06 AM
farmer ford
2000 mi on the oil. and blue smoke when it is cold no good black smoke even if it tried. io checked the turbo and it does not appear to have a ba d seal. what about injector o-rings?
Old Oct 30, 2009 | 11:22 AM
thumper869's Avatar
thumper869
it's a possibility. then again there's several possibilities when the truck is blowin blue smoke. if the smoke is just there on start up it sounds like you may have a seal in your head leaking oil onto the piston while its shutdown and when you start it up the oil burns off.
Old Oct 30, 2009 | 12:11 PM
Hussler's Avatar
Hussler
Remove your fuel filter and see if the fuel in there is black.
Old Oct 30, 2009 | 10:05 PM
farmer ford
good points. ill check the fuel in the morning. but how would i know if its a head?
Old Oct 30, 2009 | 10:12 PM
c00nhunterjoe's Avatar
c00nhunterjoe
odds are its injectors orings. aot of people mistake cold morning smoke for oil. it is normal to have a blueish tint to it but it should smell like fuel, not oil.
Old Oct 31, 2009 | 06:55 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Probably injector o-rings, but I had a few guys tell me years ago that the 7.3 PSD likes to have oil capacity showing about 1/2 way on the dipstick, not up to the full makr.
And wouldn't you know if I put in oil more than 1/2 way up the stick, it burns it off then keeps it there.
One one of my trucks, anyway. The other one it didn't matter, it would stay full.
It's 2 qts to go from 1/2 way to full, so I do w/o those 2 qts and it doesn't seem to burn anymore.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Nov 1, 2009 | 11:05 AM
farmer ford
ifn i do the injector o-rings it sounds like a good time to upgrade. should i rebuild mine to stage 1 or 2s or buy a kit for mine?
