4x4 Hubs
Old Oct 29, 2009 | 02:47 PM
Vinford's Avatar
Vinford
4x4 Hubs
2002 F-350 4x4
Can you change the factory hubs over to a Warn type hub?
I have switch on dash , so if I had Warn hubs could I lock them in and just use the switch to take it in and out of 4x4?
Old Oct 29, 2009 | 02:52 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
you sure can Ken. you dont have to leave them locked all the time but yes you can convert to warn's. you will have to plug the vacuum line going to the hub though.....
Old Oct 29, 2009 | 02:57 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Like Bill said, you can do that, but all the gears and the front driveshaft will be turning all the time. The switch on the dash only controls the transfer case. Some people do this in the winter so they don't have to get out of the truck every time they come to ice or snow. You may loose a little MPG, but that's about it.
Old Oct 29, 2009 | 05:20 PM
brian42's Avatar
brian42
Veteran: Navy
Yes you can and many people do. You will just have to get out lock/un-lock the hub.
Remember to plug the vacuum line (or lines, depending where you disconnect) for the ESOF. There's no point in having your ventilation cycle through defrost for a vacuum leak in the system you won't be using any more...
Old Oct 31, 2009 | 12:14 AM
maevans's Avatar
maevans
Originally Posted by Vinford
2002 F-350 4x4
This should help you with the install of Warn hubs. Auto to Manual Lockout Hub Conversion pictures from cars photos on webshots
Old Oct 31, 2009 | 12:25 AM
Vinford's Avatar
Vinford
Doesnt look to complicated..............thanks
Old Oct 31, 2009 | 09:34 AM
Ponyboychris's Avatar
Ponyboychris
It's not complicated at all. Hardest part for me was to get the old ones off. I had one that was stubborn (go figure, it was the broken one. ) I think it was about 10 minutes each side. Took me longer to find the right allen wrench from my rollaway for the install. I love my Warn's.
Old Oct 31, 2009 | 12:53 PM
binuya's Avatar
binuya
I prefer to get out and lock the hubs, knowing that they are definitely locked. I didn't have that peace of mind with the stock arrangement. I got lucky a couple months back and scored a set of Warn premiums for $100 off Craigslist. Pretty beefy hubs. Can't imagine what it would take to break something on them. Like Chris said, 10 or so minutes per side, depending how long it takes to remove the old hubs. Then, don't forget to plug/remove the vacuum lines.
Old Oct 31, 2009 | 12:55 PM
SpringerPop's Avatar
SpringerPop
Don't forget to plug the little ports on the hubs where the vacuum lines attach, too.
Don't want water getting into your wheel bearings.
Pop
big kahuna
6.4L Power Stroke Diesel
Dec 8, 2013 09:51 AM
Mikei70
May 21, 2013 01:11 AM
koski19
Jan 8, 2013 01:34 PM
eldorado73
Jan 21, 2012 08:16 PM
d hendrick
Offroad & 4x4
Aug 2, 2003 11:28 AM
