Rear Shackle
Old Oct 28, 2009 | 05:05 PM
Dragonfox13's Avatar
Dragonfox13
Rear Shackle
So, i've got a 95 F150 5.0/Aod 2wd, its my only vehicle
Today after leaving the yard for the storage unit the rear shackle on the passenger side broke, and has left the spring resting against the bottom of the bed, and i need to know.. Is it safe to drive this way until i can get it fixed this weekend?
can post up a pic if anyone needs it.
Old Oct 28, 2009 | 05:59 PM
gearhead351's Avatar
gearhead351
It's do-able to drive it till the weekend, but I gotta say that's pretty unsafe. If you slam on the brakes the other side could break and a flopping rear end down the highway wouldn't be fun.
If you got in an accident you could be cited for carelessness or what ever it is.. I'd say try really hard to find another ride or walk....
Old Oct 28, 2009 | 08:48 PM
doug6644's Avatar
doug6644
Usually it just ends up being the rears that rust through, unless yours is horribly rusty. I purchased a truck that obviously had the rear shackles rust through, and the previous owner drove it till the springs rubbed through the bed of the truck. The front shackles don't rust out like the rears, so I really doubt the rear-end is going to fall out. You will be fine to drive the truck for weeks, but keep in mind it could ruin your bed, and u-joints.
Old Oct 28, 2009 | 08:57 PM
Dragonfox13
well, it had just happened today, only mark on the bed is from when it smacked against it when the shackle broke and its laying on one of the cross members for the bed, drivers side looks fine and the fronts are in good enough shape. thanks for the reply's
Old Oct 28, 2009 | 09:25 PM
quicklook2's Avatar
quicklook2
in a week it will start rubbing a hole in the bed.
couple of days should be fine.
ebay has shackles and kits for cheap.
Old Oct 28, 2009 | 09:34 PM
doug6644's Avatar
doug6644
Yea, parts are reasonable, even through a dealership. The problem lies within the installation of the new parts. Takes a torch, and a BIG prybar.
Old Oct 28, 2009 | 09:45 PM
quicklook2's Avatar
quicklook2
i use a scissors jack between the frame and the spring to get it in place to bolt up.
Old Oct 29, 2009 | 01:11 PM
Dragonfox13
i plan on taking a grinder to the heads of the bolts attached to the frame, and just punching them out the other side, hopefully wont need a torch so close to the gas tank
Old Oct 29, 2009 | 04:58 PM
doug6644's Avatar
doug6644
But you will probably need to torch the bracket that is attached to the leaf spring. They are mounted in rubber, inside the leaf spring, and the bracket, with a steel sleeve, and the bolt is usually rusted to the sleeve that is within the rubber.
Old Oct 29, 2009 | 05:14 PM
quicklook2's Avatar
quicklook2
nope, you grind one or both ends off and chisel them out.
Old Oct 29, 2009 | 09:48 PM
doug6644's Avatar
doug6644
Wooaa..more of a man than I am then. Heat is your friend, torch them a while, the rubber lets go of the steel sleeve, take the entire bolt and sleeve out. Seperate the bolt and sleeve, buy new bolts, reheat the sleeve cherry hot, put it back in the bracket, and it melts the rubber back around it. Like new, and the rubber inside the leaf spring and bracket doesn't know what happened. That has been my experience, I never wanted to sit under a rusty/muddy old Ford and chisel a bolt out.
Old Oct 29, 2009 | 10:19 PM
quicklook2's Avatar
quicklook2
nope, that is not how to do it.
the fuel tank and vapors are way too close.
i have done over a half dozen trucks like this.
after you grind the ends off, it is only a couple of hits with a hammer and chisel.
mafia_jon
Offroad & 4x4
Feb 12, 2014 04:21 PM
jmm
17
Jun 5, 2012 04:29 PM
blacksmithtech
Jun 30, 2004 10:32 AM
Narwhal
Apr 29, 2004 10:13 AM
