Sticking throttle
Old Apr 24, 2002 | 06:40 AM
jowilker's Avatar
jowilker
Sticking throttle
Old Jul 16, 2002 | 07:56 PM
ranger99's Avatar
ranger99
Sticking throttle
Hi guys, I've got a '99 Ranger, 4 cyl, automatic. If she sets for 6 to 8 hours, the pedal is hard to push down. It only happens after she sets. The rest of the time she works great. Any ideas? Thanks.
Bob
ranger99
rburgoon@carolina.rr.com
Old Jul 22, 2002 | 05:37 PM
HotWhlz85's Avatar
HotWhlz85
Sticking throttle
Hey Bob,
Sounds like to me that something possibly needs a shot of lubrication. After you hit it hard the one time does it loosen up a bit? You might try a few blasts of white lithium grease at pivot points just to see.
Ron
Old Jul 23, 2002 | 10:35 PM
mwpierson's Avatar
mwpierson
Sticking throttle
[updated:LAST EDITED ON 23-Jul-02 AT 11:36 PM (EST)]I just fixed this on my 97 Expedition. I took the throttle body off and cleaned the entire housing with carb cleaner. It seemed that there was a buildup of carbon which made the butterfly valve stick to the body.
Be sure to get a new gasket... $3 at any parts shop.
Mike
Old Jul 27, 2002 | 03:42 PM
ranger99's Avatar
ranger99
Sticking throttle
Yeah, Ron, after I tap it the one time its good to go. It just sticks after it has set a good while. It doesn't stick after I tap it from then on until she sets a spell.
Bob
ranger99
Old Jul 28, 2002 | 12:40 PM
HotWhlz85's Avatar
HotWhlz85
Sticking throttle
I was thinkin about this after I read Mike's post and he's probably on the money. It's been a long time ago but I had to do the same to the butterfly on the throttle body in my Corvette. It wasn't a problem after that. Bound to be either that or a linkage somewhere that is either dry or binding up.
At least it makes sense to me....
Ron
Old Aug 10, 2002 | 11:11 AM
bubbernator's Avatar
bubbernator
Sticking throttle
Varnish is building up on the throttle butterfly. I've got the same problem on my '98 2.5l Ranger. The first time I cleaned it I shot Gumout up the intake while running. Worked like a charm. A week later I had to replace the IAC (Idle Air Control) because I'd wasted the seals with Gumout.
$55 part, don't let it happen to you.
I've cleaned it out twice since then, when I've had the intake apart for maintainance or repair. Just don't shoot it while running. Work the throttle by hand and spray the b-fly. Should take care of it.
CB
:P
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
