94 f-150 with an AOT trans?
I was trying to change the transmission filter and gasket tonight. Went to my work (AutoZone) and picked up the E4OD trans kit. Figured that is what I had as my past f-150s had them all. Get home drop the pan... not so much. Went back to the zone and looked up the other trans listings under 94... None of them looked like the one I had. Went back to a 93 to see if AOD trans was it. AOD wasn't an option AOT was. So my question, is an AOT the same as AOD? Also the gasket was right but the filter was way off! I know there was a shallow/deep pan option but the filters weren't even close! Any ideas? Why does a 94 have a 93 trans? I just bought the truck and know nothing about the prior history.
AOT? No such thing.
AOD ended in '93.
AODE maybe in an F150
4R70W in an F150 also.
Checky this out:
Ford Transmission Spotter's Guide .: Articles
This is under the "Articles/Specs" heading at the top of the page.
Good luck.
AOD ended in '93.
Checky this out:
Good luck.
4R70W good trans, as good as any.
AOT = Automatic Overdrive Transmission, a non-Ford term.
AOD = Automatic OverDrive transmission, a Ford term.
Either term could be generic, but Ford did use AOD. Some of the other designations at least add the "E" or a number than can be decoded to the torque rating.
The AOD, AODE and 4R70W are similar, kind of an evolving line of transmissions. Thus, those who want to run a beefed AOD use parts from the later two transmissions.
More info:
4R70W Transmission, Remanufactured, Heavy Duty, Performance Transmission, 4x4 - Rebuilt Transmission Ford Transmissions 4R70W Heavy Duty - Monster Transmission & Performance | 800-708-0087 | Fast FREE Shipping!
AODE and 4R70W Performance Products - Baumann Electronic Controls
AODE AODE 4R70W 4R70W AOD Mustang Parts, aode aode 4r70w Transmission
TCI - Ford AOD, AODE and 4R70W
More info:
steverinaz
06-23-2017 10:20 AM
steverinaz
06-22-2017 03:13 PM
88f150302
05-20-2010 01:54 AM
