I must be slightly confused on the operation of a blow off valve then. I always though it dumped boost after decel to combat shaft breakage. I do know what your saying about the gas engines though with butterfly and all. If this is the case then why is BD selling a product that supposed to do what i have told you its supposed to do? This is false advertisment and ill have to tell them about that.
The forged rods really give out that easy? I thought the newer powderedized ones where know for that? If thats the case there goes another $2000 on a set of racing rods.lol
Your correct in the idea, but the theroy don't really imply to a diesel engine without a butterfly in the intake. They are not really false advertising but selling a product that is completle un-needed.
The H2E has a T4i flange. It's a holset thing to be different.
The GT40 and GT42 use a T4 or T6 flange. I would say that a T4 set-up would allow for you to go with alot of different turbo set-ups.
However, a modded H2e would def. make you happy as well.
I would find a diesel performance shop you like and talk it over with them and they can point you in the right direction.
Who could i talk to about it? I dont think there are any in the pittsburgh area. The only one i know of is pittsburgh power and they deal in big stuff like detriot 60s, C15, N14s. I think i may go with the holset though. Is the H2E a ball bearing turbo?
maybe that would be the best route. I wanted to get the H2e so there was room to grow on it. I know the 38r is a good turbo but there is less room to grow on it. Guess i could always get it for my 02 and run the big daddy on the 95.
Well you have alot of growing in other places before the turbo is an issue. you can run the 38R while you save for Hybrid injectors. Those are like $2300 right there. Then a medium oil HPOP from dieselsite or terminator engineering or stealth. You will need to upgrade your fuel system some too.
If you want more than 400-450hp then you are gonna have to do a complete build. My build w/ a GT42 was gonna cost me $7500 w/out rebuild kit.
And I was going with WOP cyno'd rods.. add another $2100 on top that brice for Hypermx connecting rods.
Playing at 500hp is not very cheap with these engines.. hence why I am going w/ a 12v
Any other questions or if you want me to send you my price list for my build shoot me a PM
Good luck
Thanks alot. I have a price list for all the stuff i wanna do too. Its excedding 10000! It sucks that it costs us sooo much to make this engine fast. Internationals 444e and 7.3psd are very great engines and being that i work for international i hardly work on them casue they are so reliable. Sometimes i wish i woulda bought 6.4 powered truck. I do see your point on the 12v but im not a fan of mechanicals. I like the efficeincy of a electronic. I refuse to swap in a CR-ISB casue i have seen waaayyy too many burn #6 cly out. So maybe ill end up getting the 38r and 530s. Ill just have to live in the 450hp range for a while. Maybe ill give the wife my truck and buy a 6.4 in a few years.
When you say 530's are you talking about B-codes (BD injectors) or a set of hybrid 530 pistons and barrels in a A-code body?
If you are planning on B-codes you will want to invest in some are of big oil. B-codes and a 38R will have enough air and fuel for ~500 with the right tuning. At that power level, you should really be considering headstuds at the least, and the supporting mods fuel wise..
Stock B-codes have a 5 hole nozzle, you would be best to switch to some 7 hole psd nozzles and increase the nozzle size as well...
