Turning off my pickup
Old Oct 24, 2009 | 01:37 PM
diggidyd12's Avatar
diggidyd12
I don't know how usual this problem is but it has become quite an inconvenience. I replaced my ignition switch to avoid having to use a screwdriver like the PO did. It starts fine but will not shut off! I pulled the fuel relay fuse to kill it but this leaves the truck in the run position. So now I have to connect the battery to start it and then pull the fuel relay fuse and disconnect the battery to shut it off. This is becoming a major pain. I know that the problem lies in a spring not being engaged inside the steering column however I don't really want to tear into that. Is there a killswitch I could rig up that would shut the truck off and kill the battery? And then reengage it to start it? Its not used very much and I don't have a much time to work on ti. Any help would be greatly appreciated.
Old Oct 24, 2009 | 01:43 PM
quicklook2's Avatar
quicklook2
take out the lock cyl and put it in correctly, if you can.
or the ignition actuator needs to be replaced.
Old Oct 24, 2009 | 06:15 PM
wolfsmurf's Avatar
wolfsmurf
the electrical ignition switch on the column needs adjusting or replacing. they are slotted from the factory to allow for wear in the linkage and such.
Old Oct 24, 2009 | 06:21 PM
g_k50's Avatar
g_k50
Sell truck to someone with time or money, you don't have enough of either.
Old Oct 25, 2009 | 05:31 AM
tjc transport's Avatar
tjc transport
i ain't rite
welcome to FTE.
there is a small piece in the column called the ignition actuator. it connects the key cylinder to the ignition switch. it is broken. $13 dollar item from the dealer, and around 3-4 hours to install.
Old Oct 28, 2009 | 12:55 PM
diggidyd12's Avatar
diggidyd12
Is there any way to just run a toggle?
Old Oct 28, 2009 | 01:09 PM
Lazy K's Avatar
Lazy K
[quote=wolfsmurf;8069163]the electrical ignition switch on the column needs adjusting or replacing. they are slotted from the factory to allow for wear in the linkage and such.[/quote
You could try that. The ign switch is under the dash bolted to the steering column. Just loosen the two screws and slide the switch along to see if that helps.
Plan B is to remove the switch from the column (under the dash) and work it manually.
Old Oct 28, 2009 | 05:24 PM
Virto's Avatar
Virto
Did that. Always looks like you're trying to steal the thing, under there with a screwdriver.
Works though, did it for a couple of months until the '90 blew up.
Old Nov 18, 2009 | 07:54 AM
ricku's Avatar
ricku
take the column cover off and operate the rod (runs on top of actual column) with a pair of pliers until you fix it.
paulcalif1
Feb 26, 2014 07:35 PM
paulcalif1
Modular V10 (6.8l)
Dec 26, 2013 10:34 PM
ludude1975
1997 - 2003 F150
Aug 18, 2009 01:26 AM
flatbed444E
Dec 23, 2008 07:56 AM
Nash Green
Jan 15, 2004 10:41 PM
