Why is the speedometer not working?
Old Oct 23, 2009 | 06:00 PM
E350Bus's Avatar
E350Bus
I just drove my E350 home from the shop after having two major things done:
1. Tranny overhaul. The E40D was completely rebuilt to "bulletproof" standards.
2. Axle swap. I had the axle from a 1991 E250 with 3.73 gearing put in the van and took out the original axle (3.54).
BUT now the speedometer drops down 5 or 10 mph every 10 seconds or so, i.e. at 60 mph it'll bounce to 50 then bounce back to 60 for a few seconds then drop again. Mechanic said he put new speed sensor in the axle...
any ideas?
What do ya think?
James
Old Oct 24, 2009 | 08:51 AM
E350Bus's Avatar
E350Bus
BTW, my van is a 1993 E350.
Found this elsewhere on the web...does this ring true to anyone for a 1993 van?
"The speedometer is also used to provide speed signal for correct operation of the vehicle's EEC module and speed control (if so equipped). Because of this, it is VERY IMPORTANT to change the speedometer's internal conversion constant if the size of tires on the vehicle is changed.
Changing the conversion constant to the proper value when the tires are changed will also make sure that the speedometer retains the original factory-set accuracy."
If so, how do you change the "conversion constant" ?
Old Oct 25, 2009 | 11:16 AM
subford's Avatar
subford
Your problem is in the rear end, sounds like the tone ring is not in right.
For changing the conversion constant in the PSOM go to this link:
HOW TO RECALIBRATE THE SPEEDOMETER ON 92-96 FORD F-SERIES AND BRONCO .: Articles
BuckHammer
18
Aug 17, 2024 10:39 AM
Dean06919
May 19, 2017 04:50 AM
1993 f150 4x4
Sep 7, 2016 02:19 PM
49f3dls
May 25, 2016 07:37 AM
JIMY
Nov 16, 2004 08:12 PM
