Water leaking into cab ...
Old Oct 23, 2009 | 04:58 PM
iggyboo's Avatar
iggyboo
I did a search to see if anyone else has had this problem but didn't see anything ... although I did see some posts about the AC backing up and causing leaks but that's not my issue.
I bought this truck used last year (2005 with ~25K) and it had a clean Carfax report so no wrecks or body work, but whenever it rains, water collects inside one of the panels on the passenger side. Whenever I brake any type of hard, or turn a sharp corner, I can hear the water sloshing around and every so often the water will leak onto the floorboard of the passenger side.
I've already taken it to the stealership to see if they had any ideas, and one of the service guys said "oh, your tubing inside the door that drains the water has just come out" which he stuffed back in the door. But that didn't fix the problem. I'm just lucky he didn't charge me their normal $97 diagnostic fee for that bit of nothing.
Anyone else have any ideas or had this problem?
Old Oct 23, 2009 | 08:43 PM
svt2205's Avatar
svt2205
The 3 common leaking issues with our trucks are the AC drain, 3rd tail light not sealed and a cableway that leaks. There's a TSB for the cable issue, but I can't seem to remember the TSB number or find it by searching.
Old Oct 24, 2009 | 12:18 AM
iggyboo's Avatar
iggyboo
Yeah, I already did a search on TSB's to see if there was anything on this issue but couldn't find anything ...
alleyoopster
1983 - 2012 Ranger & B-Series
16
Oct 17, 2019 09:54 PM
BackwoodsBum
Mar 20, 2015 05:37 PM
1998Ranger25L153CID
17
Jan 29, 2015 01:55 AM
rickfitz
May 21, 2011 09:32 PM
DadsrII
Sep 29, 2003 10:59 AM
