Steering
Old Oct 23, 2009 | 01:56 AM
Tsoptich's Avatar
Tsoptich
Question Steering
I have a 74 f250 with a power steering, the problem I am having is that the steering wheel while driving has about a 1/4 turn of play before it corrects. I changed out to steering column were it leaves the cab and connects to the steering box. And I tried to weld the slip joint and change out that rubber piece with the two bolts at the steering box with a metal piece. Temporary fix but I need to know that correct way that may be low budget. Will a 2wd column work on a 4wd truck? Let me know what you think.
Old Oct 23, 2009 | 02:38 AM
75F350's Avatar
75F350
Chances are that it is not your column. You have a worn box and perhaps a worn or faulty hydraulic assist system.
Have you tried to adjust the steering box?
Old Oct 23, 2009 | 04:02 AM
Tsoptich's Avatar
Tsoptich
Thanks I will look into that. will a 2wd steering box work on a 4wd Truck?
Old Oct 23, 2009 | 08:47 AM
75F350's Avatar
75F350
No sir. They are entirely different.
Old Oct 23, 2009 | 04:27 PM
Tsoptich's Avatar
Tsoptich
oh well thanks for that, good i found out before i did anything
Old Oct 23, 2009 | 04:48 PM
Tsoptich's Avatar
Tsoptich
Can you rebuild the steering box or do you have to get a new one?
Old Oct 23, 2009 | 04:55 PM
93F22A6's Avatar
93F22A6
Trust me, get a new one. You'll be glad you did.
Old Oct 23, 2009 | 05:19 PM
Tsoptich's Avatar
Tsoptich
i think i will.
montana_highboy's Avatar
montana_highboy
Red-Head Steering Gears, Seattle WA - Red-Head Steering Gears Home
