dual quad build, what needed
currently we have 390 block, standard rotating assembly, cj heads, and an edelbrock dual quad manifold
this just what hes found so far on the property we have hundreds of carbs to choose from, we also MAY have steel crank layin around somewhere, but i dont know.
so, how do we make a 390 breath through 8v's? obviously its a high rpm engine, but how high? 6500, 7000, 8000rpm? also would forged pistons be required for this?
this is just my educated guess.
10.5:1cr
forged pistons
290/290 solid cam
roller rockers
dual 500cfm or higher?
open up oiling system
arp bolts on bottom end
headers & dual 3.5/4
possibly steel crank
#1 You need to connect the vacuum cans together. You can buy the kit, but what I did was to drill and tap the covers and install 90Deg grease fittings with the spring and ***** removed. It was kind of neat as the fittings faced each other, so a short rubber tube was all I needed.
#2 The idle circuit is designed for single carb use. You need to restrict the idle passage or you will probably wind up with all 4 idle mixture screws all the way in, which works satisfactorily, but isn't optimized
#3 You need to drill a hole in the secondary carb bell-crank closer to the pivot point to get the mechanical advantage that allows the carbs to hit WOT simulatanously.
Eventually, I had Pony Carbs fix me up a pair of new ones. They seem to work the same as what I had, but I do have more range adjustment on the idle screws and they wound up somewhere betwen 1/4 and 1/2 turn out.
The front carb opens approx 30% before the rear one but due to the linkage being more agressive on the rear, they both wind up at WOT at the same time. See mod #3 above.
I havn't found a need to have the transfer slot open at all. If I try for that, my idle is way too high even with the secondaries adjusted just shy of sticking. Just adjust the idle stop screws evenly to get the idle you want, ...don't leave one carb closed and adjust the idle with the other. Balance them.
I use the lightest vacuum springs available (but not the shorty ones) with no trouble. Heavier vehicles may require stiffer springs (Holley kits are available).
Again, two carbs delivering twice as much fuel as required through the idle passage when at idle. I first used two generic carbs, and really couldn't get the idle to peak with the screws. All the way in seemed to be "almost" right. Guess some fuel must have been drawn through the transfer slots even though they wern't uncovered. Restricting the idle passages in the primary metering block is the answer.
The idle circuit is set by a fixed jet and is a rough setting. Fine tuning is possible by the adj screws. With twin carbs, it seems that even with the adj screws all the way in, the idle can be too rich. Carbs designed for 2x4 operation should have this taken care of, but if you purchase two carbs, each designed for single opration, you can have a problem.
The answer is to have a carb shop replace the idle jets with smaller ones, or to insert a fine "V"-shaped wire into each of the jets to effectively reduce it.
Here's a bad pic from Dave Emanuel's book on Holleys:
I found stock carbs did run OK, but with the screws all the way in. I replaced them eventually with units from Pony Carburators and they must have done something to the jets as I can now run with all screws about 1/4 to 1/2 turn out.
Edit: Two more things. 1/ If you need dimensions on wherre to drill the rear carb bellcrank pivot hole, let me know and i cna measure it for you. 2/ You also need cross-over linkage as the carbs are mounted reverse of normal (primary's towards the back of the engine). It's still available. I've seen it somewhere on the net. If you can't find it, let me know and I'll see if I can find it.
Here's a pic of the cross-over linkage from Gessford's:
and here's a pic of it installed:
It'll last a lot longer if you hold it to 6500....
Have you considered going bigger with a stroker crank? A 390 will go to 445 if you get a stroker.
Good luck with it.
428 IU crank
TRW Forged pistons 9.5:1
Sealed Power rings
stock rods with ARP bolts
clevite bearings
API balancer
Aftermarket timing gear set (forget the make)
Crane solid lifter Fireball cam, 294 adv duration
Crane solid lifters
Crane pushrods
Crane adj rocker arms
Crane valve retainers and caps
Crane dual valve springs
Harland Sharpe single hole hardened rocker shafts
FPP end and center rocker support stands
FPP solid rocker spacers
HV oil pump
Heavy duty oil pump drive
Oil gallery between pump and filter enlarged
Oil holes in main bearing saddles chamfered to align with holes in bearings
Resitrictors put in oil gallery's to rocker shafts
Lifter oil galleries blocked off
Large gallery oil filter adapter
FEl-pro HP gaskets (very important for head gaskets)
Mallory non-vacuum dist with Pertornix Ignitor
can't think of anything else at the moment...
It may be wise not to limit yourself to TRW, or even forged. Hypereutetic are a very good alternative to forged.
Flatlander Racing - TRW Pistons
Ford 390 410 427 428 Pistons Ross FE Engine Forged Pistons
On my list in the previouus post, you can add a windage tray, large-tube oil pick-up (Boss 302 fits, although I switched to Aviad pan and pick-up), and I forgot to mention, I adjusted my oil pump for 85 psi max.
Probe now lists a 390 dish and flat top. Not sure on current availability yet - but should be priced fairly and a good quality part. Hypers are just fine in fuel injected, electronically managed vehicles where knock sensors and O2 sensors will protect the engine. I would not run them in anything carbureted that I cared about. A risk taken with no reward.
I probably shouldn't have made the comment about using hypereutectic pistons. I did have a basis for it though. A friend of mine kept blowing up his boat engine. A Mercruiser inboard/outboard...basically a Chev 350 for an engine. It had been rebuilt using automotive parts when he bought it (vs Mercruiser parts). He broke pistons (cast), rods (stock) and even a crank (cast). Finally, he put in a steel truck crank, aftermarket rods and hypereutectic pistons. Never a problem after that. And a boat engine runs pretty hard for long periods of time. Carburated engine, 16 ft boat, 64 mph. So it seemed to me that hypereutectics were pretty good. Maybe they worked for him, but were at their limit.
*yes, to most of you, I am a foreigner, but I'm sure you catch my drift. LOL....when I visit the USA, I'm an "alien" !!!
The LR setup also fit under the stock Cougar hood. He originally had a leetle Crower Monarch potato cam in it, ran alright but nothing special, I got him a 290/570 juice cam from Holman Moody that brought it to life- actually was pretty strong at that point. And it won't be a high-RPM screamer, you an run an MSD 6AL with a 6000 chip and it'll run forever. Don't need a steel crank, but good rod bolts- and if you happen on to a set of the 13/32 bolt rods, so much the better, and still fairly light
