5.4 290Kw Boss Supercharged
Ok you guys im looking for some help in the supercharger department.
I have a 2003 Ford BA Falcon PURSUIT ute (Australian).
I comes with a standard 5.4L DOHC the spec's as below
I want to put a supercharger on like the holley one in the attached web address, what is the brand of the standard supercharger on the 2003 F150 lightning?
Engine Type Boss 290 - High-performance 5.4L Quad Cam 32 valve V8
Max. Power 290kW@5,500rpm
Max. Torque 520Nm@4,500rpm
Engine Size (cc) 5408
Compression Ratio 10.5:1
Bore x Stroke 90.2mm x 105.8mm
Boss 290 Engine Components
Pursuit
FPV High-Compression Pistons and Piston Ring pack
FPV Re-engineered Conrods with Fully Floating Gudgeon Pin
FPV High-Lift Inlet camshaft (13mm lift)
FPV High-Lift Exhaust camshaft (12mm lift)
FPV Valves, Valve Springs and Finger Followers
FPV Balanced Crankshaft
Heavy-Duty Bearings
75mm High-Flow Throttle Body with Drive-by-Wire control
FPV High-Flow Air Intake System
FPV High-Rise Long Runner Intake Manifold
FPV Stainless Steel Fabricated Exhaust Manifolds
FPV High-Flow Dual Exhaust System
High-Capacity In-tank Fuel Pump
http://www.holley.com/HiOctn/ProdLine/Products/AMS/SC_pics/f300-520.jpg
Pursuit
Heavy-Duty Bearings
Eaton makes the Lightning Supercharger, but you'll need to go easy on the boost. Your compression ratio is pretty high for a supercharger, without making sure your head gaskets are durable enough. I would also worry about pretzeling the conn rods.
Post a picture, I haven't seen your Australian spec vehicle.
You'll have to find another supercharger. You have DOHC heads and that kit is designed for 5.4 2-V apps. in the F-150. The lower intake that kit comes with won't fit. You might be able to modify your existing lower intake but I'm not famiar with what intakes are offered on the Australian 32V 5.4's whether they are Navi. lowers or something similar to the Cobra R castings... Look up MTC Forums.....there are some experts there that have great info.
BigBlocker0248
27
07-01-2016 03:25 PM
Rusty_S
31
11-17-2010 08:15 PM
