lighting autometer gauges
Old Oct 22, 2009 | 05:39 PM
sanders92's Avatar
sanders92
I am installing a set of autometer boost and egt gauges to my 2003 f350 (6.0) and I am looking to see where I can find a wiring diagram so I can wire in the lighting for the gauges. I can pop out the head light switch assembly very easy and would like to tap into those wires but not sure which ones to use. can anyone point me where I can find the info?
Thanks
Old Oct 22, 2009 | 07:04 PM
06silvercrew's Avatar
06silvercrew
Here you go
Old Oct 22, 2009 | 07:54 PM
1975StroppeBaja's Avatar
1975StroppeBaja
yep... Just like the diagram says, I tapped into the light blue/red wire of my headlight switch for mine.
I don't know which series of Auto Meter's you're running, but if you find yourself unhappy with the illumination, you might check out the bottom section of my gauge writeup for a way to make it better for much less $$ then Auto Meter wants for the LED upgrade.
2004 F250 Quad Gauge Install
Good luck!
Old Oct 22, 2009 | 10:55 PM
rocky1074's Avatar
rocky1074
Thanks for the tip on the bulbs...I just ordered myself 10 bulbs. Not bad comes to 1.90 per bulb shipping included.
Old Oct 23, 2009 | 09:15 AM
1975StroppeBaja
Yeah, that's a good price considering Auto Meter wants about $10/ea for them from Summit Racing.
I've had them in place for quite a while now and they are still working just fine.
Old Oct 23, 2009 | 06:56 PM
sanders92's Avatar
sanders92
yeah that is exactly where I tapped into was the blue/red wire. also one of light bulbs did take a crap on me so I was going to look into different bulbs. thanks for the info!!
Old Oct 23, 2009 | 07:08 PM
sanders92's Avatar
sanders92
also stroppebaja nice job on the gauge install post!!
Old Oct 23, 2009 | 07:24 PM
conger's Avatar
conger
One of my gauges came with a bad socket for the lamp. I got it exchanged right away while still putting things together and no problems since. All in all I'm fairly happy with Autometer.
LLAMASvsROBOTS
Sep 15, 2014 09:28 AM
strokingbeast
Nov 23, 2010 10:47 PM
jopiel
Aug 17, 2007 09:56 AM
Highmark18
May 1, 2007 02:24 PM
Ultraute
Electrical Systems/Wiring
18
Jul 12, 2006 09:22 PM
