Tons of problems, but heres the worst
After rotating my tires today I went for a drive to see if the road noise that had mysteriously appeared overnight was gone (which it didnt). Shifted into second and almost hit my head on the rear window, same thing into third gear. Looked down and my OD light was fllashing. Same thing happened to me when I first bought the truck. Anyways it seems like the torque converter wont lock up. RPMS are always 3-500 higher than what they normally are and it will rev up if you step on it without downshifting right away. So i went back to the farm and unhooked the batteries and took out my ICP and EOT mods and put it back to stock. Took it out and now the OD light doesnt flash and the second and third gear shifts arent too rough but it still isnt locking the TC. Truck is at normal temp ranges on oil and tranny fluid but it seems like it runs like it does on cold mornings for the first two miles. New trans 40k miles ago, warrantied 3 yr/75k miles and that three years is up in less than 2 months so i gotta figure this out asap. Can anyone help? My thoughts are the trans is toast since its exactly what happened last time, but itd be great if i didnt have to to get it replaced, not to mention if they void my warranty because of the mods.
When that happened to mine (limp mode) , it was a break in the wire leading to the VSS on top of the rear axle . The problem on mine was intermittent , due to the insulation on the wire wasn't broken , but the wire inside was (soft spot ).You may want to have the code read ...
well i dont think an open element air filter will give you 100hp! lol so i dont think that would void a warranty, but take out the icp, no one will know that you have tghe idm mod in there unless you open your mouth, but yes sounds like your tranny might be toast, its in limp mode. take advantage of a new tranny if you can! see ifyou can throw them in some extra doe in the replacement to get some good red label parts.
Decipha
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
13
03-03-2015 08:47 AM
lablue96
12-15-2011 06:40 PM
