Hey, has anyone had any rust issues covered under warranty? Seems like the warranty is ten years or something like that. How do they(dealer) deal with something like that? If I have a spot the size of a golf ball that is growing under the paint along my wheel well(where a fender flare would sit), will they do anything about it? I really take care of my truck, so I find it hard to believe this would form on its own unless there was an underlying issue, but I also don't baby my truck. Maybe could have started out as a small paint chip and water got underneath it. Just curious. I don't want to have it spread up into the bed side when I can tackle it now and maybe even throw some fender flares on after I have stopped the spreading.
My 01 started the bubbling a few years back. I called ford, rust is covered for 10 years unlimited mileage as i remember correctly, but there must be perforation i.e a hole or body panels pulling apart. The problem with the rear wheel wells is that there are two pieces of metal sandwiched together with a void inbetween the void is filled with what appears to be a fiberglassy insulation material, which would naturally hold moisture. My bed went from bubble to completely rotted out bedsides within two years time. I replaced the whole bed with a take off, but LMC truck now makes the cutouts. 169 per side as I recall. So to answer your question I think ford should do something about this issue, but did they....no. Will they..maybe if enough people complain!! Good luck!
My supervisor here at work has the same F150 that I do only his is newer, he had the common rust at the bottom of the tailgate with less than 40k on the dash. Had it repainted under warranty a couple years ago. Just traded it in a few weeks ago and he says the rust was already back through the new paint.
That's weird, I live in the salt belt, and have no rust on the outside body nor the bed whatsoever. Underneath, the edges of certain things are starting to get a little rusty, but well, that's to be expected, I have to start doing something about it very soon
