do you think that the ccv hose could be run out the ex tip via welded bung and hose clamp ??? right now i have it ran out the bottom of the truck under transfer case, no big deal but i live on a dirt road and it blows dust.
IIRC this has been done. You have to install the bung at a certain angle to keep the fumes exiting the exhaust. Also IIRC it was recommended by some not to do it, and some liked it.
Dave, I think the concern is the exhaust will pressure up the Crank Case, and start leaking at some seals. This has been tried before and some have done test on this.
